Renick Performance intake concerns
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Like Tree10Likes
Cadillac ATS-V Series Forum Discussion, Renick Performance intake concerns in Cadillac V-Series Forums; Finally got a chance to install my Renick Performance (RP) Intake and catch can. Here's the main issue I have. ...
    Almtyscuzzy1's Avatar
    Almtyscuzzy1 is offline Cadillac Owners Fanatic
    Automobile(s): 2016 ATS-V
    Mar 2018
    Massachusetts
    140
    1. The original driver's side MAF will not go into the RP slot for the MAF. Under normal driving conditions things should be fine with the swapped MAF meters, but when the ECM needs to make a change like duty cycle for the wastegate, it will be made for the wrong turbo. Left an email for RP Performance and I know the issue will be corrected.
    Closeup of MAF meters connectors (NOT in original position)
    TwinTurboFan and jp1seattle like this.
    slicky is online now Cadillac Owners Fanatic
    Automobile(s): Still Stock 2017 ATS-V 6MT CWT Sedan, Tuned 2016 Explorer TT
    Jul 2017
    Chicagoland
    472
    Re: Renick Performance intake concerns
    Not sure I understand the issue. If he MAF locatiin as been changed, this intake requires a tune.
    Mar 2018
    Massachusetts
    140
    Quote Originally Posted by slicky View Post
    The MAF and it's connector harness shown on top in the 2nd and 3rd photos needs to be on the bottom and vice versa. The MAF shown from the top in the 2nd and 3rd photos will not fit into the MAF slot that goes to the driver's side turbo as shown in the video.
    I hope that helps
    Scuzzy
  5. #4
    Renaldo1's Avatar
    Renaldo1 is offline Cadillac Owners Fanatic
    Automobile(s): '16 ATS-V MT6 Sedan, Alfas: '67 Duetto, '84 GTV6 3.5L 24v/Vette C5 project
    Aug 2013
    Great Pacific Northwet
    424
    1st I've heard of this. Correct me if I'm wrong, but the intake tubes can be rotated (and thus the MAF positioning), so you can adjust your install to insure the MAFs install without any interference?
    bucolic and RYRO14 like this.
  6. #5
    RYRO14 is offline Cadillac Owners Member
    Oct 2017
    48
    This intake requires a tune. Do not drive the car hard with this intake without getting it tuned for. It throws fuel trims off by 15-20%, but shifts the frequency range so that tuning becomes easier when you increase boost.
    Sent from my iPhone using Tapatalk
  7. #6
    jp1seattle's Avatar
    jp1seattle is offline Cadillac Owners Fanatic
    Jan 2018
    158
    Quote Originally Posted by RYRO14 View Post
    Heís tuned.
  8. #7
    Leesrt's Avatar
    Leesrt is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 ATS-V Coupe (Catti-V)
    Dec 2017
    Florida
    1,331
    Quote Originally Posted by jp1seattle View Post
    He’s tuned.
    Is he tuned for the intake? Being tuned is no different then stock if it hasn't been tuned to include the intake.
    Mikeyboyeee likes this.
  9. #8
    Leesrt's Avatar
    Dec 2017
    Florida
    1,331
    Quote Originally Posted by Almtyscuzzy1 View Post
    I hope that helps
    Scuzzy
    Try messaging him on FB might get a quicker response. Hopefully that response isn't how he's sold 2 million of those intakes and no ones had an issue (implying it's your fault).
  10. #9
    jp1seattle's Avatar
    Jan 2018
    158
    Quote Originally Posted by Leesrt View Post
    I know this. Iím figuring he knows this too. I think the point is the fitment of the MAF as opposed to if the cars tuned for it. Gotta get it connected properly first.
  11. #10
    FL103Dave is offline Cadillac Owners Fanatic
    Automobile(s): 2015 ATS 2.0T (gone), 2016 ATS-V, 1968 Corvair, 1974 Corvette, 2003 HD Road King
    May 2015
    SW Florida
    52
    209
    2 million intakes for a total build of ~3500 cars?
  12. #11
    Leesrt's Avatar
    Dec 2017
    Florida
    1,331
    Quote Originally Posted by FL103Dave View Post
    That wasn't meant to be literal
  13. #12
    May 2015
    SW Florida
    52
    209
    OK - I took it as such, sorry
  14. #13
    Oct 2017
    48
    I just got my intake in the mail. Hope I donít have any MAF fitment issues.....
  15. #14
    Glennhl is online now Cadillac Owners Fanatic
    May 2018
    149
    I'm a little confused after watching the attached video. You said, airflow from the right. The arrow on the sensor should not point to where the airflow is coming from, it should be pointing to where the airflow is going to.
  16. #15
    Mar 2018
    Massachusetts
    140
    Let's start with the last question first.
    1. On any tonsil or slot style MAF sensor, one side of the MAF will have an opening for airflow. This open side should be pointing in the direction of where air flow is coming from. This is how air enters into the MAF sensor. In the video, I show the opening on the slot style MAF sensor, and it needs to point in the direction of the air filters.
    2. You can't rotate the U-bend pipe in order to move the location of the MAF slot because they're in a fixed position.
    3. If you look at your MAF sensors, where the harness plugs into them are different. The MAF that goes to the driver's side turbo has its connector mount raised up in the back. The MAF that goes to the passenger side turbo has a lower connector mount. If you look at you MAF sensors and pull off their pigtail harness you'll see what I'm talking about. This applies to stk. or cars with an aftermarket intake.
    4. In the video, the MAF sensor with the raised up connector will not fit into the U-bend pipe because the slot for the MAF was welded in the wrong position. This wrong position or angle prevents the driver's side MAF from dropping in, as shown in the video.
    5. James Renick from RP Performance contacted me immediately. He stated that he had some issues with the company that cuts the intake pipes for the MAF sensors. When I return from vacation, RP Performance will send me a new U-bend pipe along with the missing hardware for the heatshield. I was impressed with the customer service before the sale, but I'm just as impressed with the customer service after the sale.
    Thanks
    Almtyscuzzy
Similar Threads
  1. FS: Renick Performance ATS-V Downpipes
    By SEATSV2016 in forum ATS/ATS-V Parts For Sale
    Last Post: 04-20-18, 07:08 PM
  2. New renick performance coming soon?
    By atsv911 in forum Cadillac ATS-V Series Forum
    Last Post: 11-15-17, 03:16 PM
  3. Renick performance charge pipes
    By connore in forum Cadillac ATS-V Series Forum
    Last Post: 09-10-17, 09:59 PM
  4. Renick Performance Carbon Fiber Mirror Covers
    By 3Point6 in forum Cadillac ATS Picture and Appearance Forum
    Last Post: 05-18-17, 07:51 PM
  5. Shopping for downpipes....New Era VS Renick Performance
    By King_Dado88 in forum Cadillac ATS-V Series Forum
    Last Post: 03-28-17, 09:19 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
