OEM wheel weight
cadillac ats forums cadillac ats forums
Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By Phantom14
  • 2 Post By BlkVee
Cadillac ATS Picture and Appearance Forum Discussion, OEM wheel weight in Cadillac ATS Forums; Anyone knows what is the weight for the 18 inch oem wheel from ATS coupe?...
    ahs2m2 is online now Cadillac Owners Member
    Apr 2019
    8
    OEM wheel weight
  3. Remove Advertisements
  4. #2
    Samephil is offline Cadillac Owners Member
    Automobile(s): ATS
    Mar 2017
    24
    Very heavy when you factor the run flat tire on it
  5. #3
    SaveTheManuals is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS 2.0T 6spd manual Performance RWD
    Jan 2018
    Ohio
    36
    348
    Re: OEM wheel weight
    Fronts are lighter than rears since they are narrower
  6. Remove Advertisements
  7. #4
    Apr 2019
    8
    Do you think it’s heavier than this 18 inch?
  8. #5
    quiksilver81 is offline Cadillac Owners Member
    Automobile(s): 2015 ATS 2.0T Performance trim 2007 CTS w/Sport Appearance & Performace Pkg - Sold
    Jan 2010
    Tampa, FL
    35
    73
    If you look on the Cadillac website you can find the brochures for previous model years. The brochures won’t say weights but it will say if the wheels are cast or forged. That will give you an idea if one will be heavier than the other. Forged wheels are typically lighter than cast.
  9. #6
    Phantom14's Avatar
    Phantom14 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS 3.6L AWD Performance
    Jan 2017
    Langley, BC
    48
    335
    Quote Originally Posted by ahs2m2 View Post
    I haven't seen specific weight specs for the coupe wheels, but I know when I found info for the 18" wheels on the sedan, the standard ones were forged and 24-25 lbs. The 'premium' multi-spoke wheels are cast and heavier - closer to 29 lbs. I'd expect the specs for the 18" wheels on the coupe to be similar, i.e. yours are probably forged and 24-25 lbs. each...forged > cast - lighter and stronger.
    SaveTheManuals likes this.
  10. #7
    Apr 2019
    8
    I thought this one is the premium standard 18 inch wheel. Which of the two is lighter?
  11. #8
    BlkVee's Avatar
    BlkVee is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V, 2013 ATS 2.0T
    Feb 2014
    235
    From https://www.cadillacatsowners.com/sho...ory-ATS-wheels
    The 17x8" painted wheels for the base model weigh 23.52 lbs each.
    The 17x8" polished wheels for the Luxury collection (optional on base) weigh 25.26 lbs each.
    The 17x8" painted wheels for the Performance collection weigh 25.26 lbs each.
    The 18x8" machined wheels for the Premium collection (optional on Performance) weigh 24.32 lbs each.
    The 18x9" machined rear wheels for the RWD Premium collection weigh 25.11 lbs each.
    The 18x8" polished wheels (optional on Luxury or Premium collection) weigh 28.84 lbs each.
    The 18x9" polished rear wheels (optional on RWD Premium collection) weigh 29.67 lbs each.
    I'm guessing the coupe's wheels would be around 25 lbs
    Phantom14 and SaveTheManuals like this.
  12. #9
    Jan 2018
    Ohio
    36
    348
    Weird those would be different lol.
  13. #10
    BlkVee's Avatar
    Feb 2014
    235
    Quote Originally Posted by SaveTheManuals View Post
    Different 17" wheels perhaps? I can see there are at least 3 different 17" wheels. Perhaps one is lighter than the other.
  14. #11
    Jan 2018
    Ohio
    36
    348
    ^True, but for a couple years there was only one 17" wheel (middle one above). That would make sense though, so those stats must take into account all years.
  15. #12
    Apr 2019
    8
    Can someone please confirm which one is the standard 18 inch Premium trim wheel for the ATS?
  16. #13
    Phantom14's Avatar
    Jan 2017
    Langley, BC
    48
    335
    Snagged from the 2016 brochure:
    So for the wheels in the pictures (A-E are sedan, F-H are coupe), if we assign to them...
    A B C D
    E F G H
    (A) 17x8" painted wheels for the base model weigh 23.52 lbs each.
    (B) 17x8" painted wheels for the Performance collection weigh 25.26 lbs each.
    (C) 17x8" polished wheels for the Luxury collection (optional on base) weigh 25.26 lbs each.
    (D) 18x8" polished wheels (optional on Luxury or Premium collection) weigh 28.84 lbs each. (F) should weigh the same on the coupe
    (D) 18x9" polished rear wheels (optional on RWD Premium collection) weigh 29.67 lbs each. (G) should weigh the same on the coupe
    (E) 18x8" machined wheels for the Premium collection (optional on Performance) weigh 24.32 lbs each. (H) should weigh about the same on the coupe
    (E) 18x9" machined rear wheels for the RWD Premium collection weigh 25.11 lbs each. (H) should weigh about the same on the coupe
    So to answer your question, (E) is the wheel that comes (or came ) as standard equipment on a Premium trim sedan. I stand corrected regarding the multi-spoke 'premium' wheel, as I duly note that they are in fact forged, not cast. The extra weight on them can be attributed simply to the extra material required for the design. I should also explain that I described wheel (D) as 'premium' (sorry for the confusion) because it's the only wheel that isn't standard (& hence carried a premium cost) on any sedan trim level.
  17. #14
    Apr 2019
    8
    Phantom14,
    Thanks. Very useful information.
  18. Remove Advertisements
Similar Threads
  1. Stock rims weight vs Replica rims weight?
    By jdubh25 in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 03-16-12, 03:32 PM
  2. Actual Weight for Factory OEM 22" and Replica 24"
    By icejava in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 11-09-11, 07:24 AM
  3. Weight of OEM Wheels
    By RB190 in forum 2009-2015 Cadillac CTS-V General Discussion
    Last Post: 08-01-10, 01:22 AM
  4. Wheel weight comparo:OEM,accessory, TD
    By soflarick in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 04-18-10, 10:48 AM
Read about Lincoln | Buick | Genesis 70 Forum | Kia Forte Forum
