ATS Performance Mods - 3.6 AWD - Page 2
cadillac ats forums cadillac ats forums
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Like Tree7Likes
Cadillac ATS Performance Forum Discussion, ATS Performance Mods - 3.6 AWD in Cadillac ATS Forums; Originally Posted by NewtPL36 FE3 rear bar on an FE2 3.6 AWD with presumably an already bigger front bar than ...
  1. #16
    Phantom14's Avatar
    Phantom14 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS 3.6L AWD Performance
    Jan 2017
    Langley, BC
    48
    333
    Re: ATS Performance Mods - 3.6 AWD
    Quote Originally Posted by NewtPL36 View Post
    FE3 rear bar on an FE2 3.6 AWD with presumably an already bigger front bar than a 2.0T AWD ....
    I haven't made the jump yet, but some additional recent research has me planning to bypass the 19mm (per previous thread) FE3 rear bar (3.6 AWD/FE2 stock rear is 14mm, front has been pegged at 23-26mm - V6 bar may be thicker than I4's) and go straight up to the ATS-V's 26mm rear. I saw (FB group, I believe) where someone installed both the F&R OEM V-spec'd. bars on their RWD ATS, and the rear compatibility seems to be confirmed by the details for <ZZP's rear bar>. According to ZZP's comparables for ATS rear sway bar options...
    Stock (non V) 14mm solid (presumed FE2 spec)
    Stock (V-model) 26mm hollow
    ZZP rear sway bar 26mm SOLID
    Brand E(ibach) 19mm HOLLOW
    It should be noted that ZZP also has an AWD-suitable <front bar> upgrade, though at 27mm, the few mm you'd gain may not be worth the expense and effort.
    The cost of the OEM parts is very reasonable @<$100: the rear ATS-V sway bar is p/n 84008631, which may include bushings (parts counter would need to confirm). At $170, the ZZP bar isn't unreasonable, either. The attached sway bar links and brackets are the same p/n from base to -V, so the bar and bushings would be all you need to upgrade. That change should significantly flatten your directional transitions, and as Sydtron noted, "...you will adapt." and most likely with a big grin on your face. When there's snow to deal with, I don't expect my snow-tire-equipped-AWD rear end to be any harder to control than when I've had small-block-powered RWD with all seasons, so I can live with that...lol.
  3. #17
    Sydtron is online now Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 3.6 Premium RWD
    Sep 2015
    Grand Rapids, MI
    36
    195
    Quote Originally Posted by Phantom14 View Post
    14mm to 26mm - that is a huge jump in size, although I'm not sure how their solid to hollow transition backs down the expected increase in roll stiffness. Just to throw out a guess, somewhere around 300-400% increase in roll stiffness wouldn't surprise me. If you are only doing the rear bar, that seems to me to be a bit too extreme and could change the balance too much. I'd just go with the FE3 bar personally.
    Phantom14 likes this.
  4. #18
    Phantom14's Avatar
    Jan 2017
    Langley, BC
    48
    333
    Quote Originally Posted by Sydtron View Post
    Thanks, and that's valid input to keep in mind - I'll keep on researching things. Using the rear V bar would create a situation where the front and rear bars would be virtually the same size (on an AWD V6 ATS, at least), based on speculation that that bar is on par with Eibach's 29mm upgrade solution. The ZZP bars are 27mm front and 26mm rear, so 'somebody' thinks an ATS would benefit from an almost-balanced setup, but that doesn't automatically mean it would make a good 'street' setup. The FE3 option is certainly the safer choice.
  6. #19
    NewtPL36 is offline Cadillac Owners Member
    Automobile(s): 2017 ATS 3.6 Premium Luxury AWD DAB (Dark Adriatic Blue)
    Mar 2019
    Canada- Ontario - Anc - Ham
    52
    So I'm gonna measure my bars with a caliper .... That's the fastest way to what I have ....
    What's RWD V6 FE3 front (??mm) and rear (19mm) ??????
    Once I know how much smaller the FE2 front bar is compared to the FE3 front bar then it'll give me some comparison to go by ....
    Sent from my XT1635-02 using Tapatalk
  7. #20
    Phantom14's Avatar
    Jan 2017
    Langley, BC
    48
    333
    Looking forward to your findings! ZZP indicates the OEM front is 23mm, but doesn't say whether that's AWD/RWD or FE2/3. The V6 AWD bar is supposed to be really chunky already (>25mm???), but that measurement is one of the few to escape confirmation. The front bar on FE3 is alleged to be 25mm, vs. 23mm for FE2.
    As added context, the 'sweet spot' according to this thread is FE2 springs with FE3 sways - for a RWD 2.0T, at least. Upgrading the front AWD bar probably isn't necessary/worth the expense; ZZP's 27mm front bar may be the only AWD-friendly option.
  8. Remove Advertisements
Read about Lincoln | Buick | Genesis 70 Forum | Kia Forte Forum
