2014 ATS 2.0T Water dripping outside below drivers seat
cadillac ats forums cadillac ats forums
Results 1 to 5 of 5
Cadillac ATS General Discussion Forum Discussion, 2014 ATS 2.0T Water dripping outside below drivers seat in Cadillac ATS Forums; So I'm out of the B2B warranty and looks like I hit my first problem. I noticed water dripping on ...
    mclarenrulz is offline Cadillac Owners Member
    Automobile(s): 2014 ATS 2.0T
    Jul 2014
    California
    13
    So I'm out of the B2B warranty and looks like I hit my first problem. I noticed water dripping on the ground right below where the driver's pedals are. I scoured though all threads on this forum and I didn't find any posts about this. There were posts about water pooling up on the driver's side carpet area but the carpets are completely dry. I checked the color of the liquid and it's transparent, so I've ruled out coolant/washer fluid. The liquid is not oily to touch (it’s definitely water). Any ideas what's going on ? Has anyone hit a similar issue and found a fix ?
  3. Remove Advertisements
  4. #2
    rsingl's Avatar
    rsingl is online now Cadillac Owners Connoisseur
    Automobile(s): 2014 ATS 3.6 Premium RWD, 2016 Corvette Z06, 2018 GMC Sierra Denali 2500HD Diesel
    Sep 2007
    2,220
    Re: 2014 Cadillac ATS 2.0T Water dripping outside below drivers seat
    Sounds like condensate from the air conditioning system is finding its way in that direction. One of the ATS design issues is a poor condensate drain system which helps create the musty HVAC odor issue.
    Does it feel oily? If not that rules out brake fluid which comes in many colors.
  5. #3
    Submariner409's Avatar
    Submariner409 is offline If it won't run, install a sound system
    Automobile(s): 2002.5 F55 CORSA STS, 2014 Explorer XLT FWD
    Feb 2006
    MD Eastern Shore, Kent Island
    79
    64,892
    Re: 2014 ATS 2.0T Water dripping outside below drivers seat
    Sounds like normal A/C condensate. At least its dripping on the ground, where it's supposed to.
    Someone will know exactly where the rubber drain elbow for condensate is on the ATS models. My STS pisses away happily on the passenger side of the lower HVAC stack, down at the turn of the firewall to floor pan.
    The drain sometimes gets clogged with lint and then the drain sump overflows onto the front footwell carpets.
  6. Remove Advertisements
  7. #4
    Jul 2014
    California
    13
    Quote Originally Posted by rsingl View Post
    nope, not oily. It’s definitely water (Updated post)
  8. #5
    rsingl's Avatar
    Sep 2007
    2,220
    Since it is water, that is almost certainly from the AC system and collecting water is normal (it dehumidifies air as it cools it) but if you are suddenly noticing a lot of water in a different place then it sounds like the drain tube may be clogged.
    I looked at the GM parts online site but they don't provide a detailed view of the case around the evaporator which is where the drain will be located. The AC evaporator (which is where the condensate originates) and the heater core are located in a case on the passenger side of the ATS so you should be able to trace the water trail back to that area if it is AC condensate. Basically make sure the drain hole is open and hasn't been closed up by debris or insect activity. I recall GM had some TSBs about the drain issue associated with the "swamp" odor from the HVAC system so there are likely multiple variations of the drain outlet for the ATS.
  9. Remove Advertisements
Similar Threads
  1. water dripping, can it be water pump - STS 2001
    By john19999 in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 04-21-18, 10:06 AM
  2. 2014 ATS Chrome Center Stack bars(or buttons) that are below the CUE screen
    By motownsax in forum Cadillac ATS Picture and Appearance Forum
    Last Post: 04-17-14, 10:40 AM
  3. 2014 Cadillac CTS 3.6 vs. 2014 Audi A6 3.0T, 2014 BMW 535i xDrive, 2014 Mercedes-Benz
    By ep_83 in forum 2014+ Cadillac CTS General Discussion
    Last Post: 12-06-13, 09:33 PM
  4. Anyone else have a water leak on the drivers side by the sun visor dripping down
    By Mangtas83 in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 11-10-12, 03:54 PM
  5. Drivers side floor wet and dripping 97 STS
    By TBONESTONE in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 04-10-08, 11:42 PM
Read about Lincoln | Buick | Genesis 70 Forum | Kia Forte Forum
