AC produces hot air from the passenger side - ATS 2.0T 2016
cadillac ats forums cadillac ats forums
Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Like Tree27Likes
Cadillac ATS General Discussion Forum Discussion, AC produces hot air from the passenger side - ATS 2.0T 2016 in Cadillac ATS Forums; So yet another issue with this ATS car. Absolutely, the worst experience I have ever had with cars. GM and ...
    ATS4EVER is offline Cadillac Owners Member
    Automobile(s): 2016 ATS 2.0T AWD
    May 2013
    57
    So yet another issue with this ATS car. Absolutely, the worst experience I have ever had with cars. GM and Cadillac suck big time. So my AC is synced on LO on both driver and passenger side. I get cold air on my driver side and hot air on the passenger side, but wait! LISTEN TO THIS! After I took the car to the Cadillac dealer to fix, they told me, after third attempt, that GM says not to fix because it is a normal behavior to experience +-12 degrees difference between driver side and passenger side and they gave me a pager saying the same with GM logo on it. Is this normal? does this sound normal to anyone here? It doesn't to me. It sound like they are trying to avoid fixing a defect in their product. Has anyone experienced anything like that before? Please let me know.
    Also, I trust the difference in temperature exceeds 12 degrees at some occasions, but it is impossible for me to measure. Regardless, it does not make any sense that I am getting temp of 65 on my side and my passenger is getting 77 on their side. No car should operate like this. What .. is GM going backwards? This embarrassing! I am embarrassed every time I take this Cadillac anywhere.
    I appreciate any info if someone else experience a similar situation. Thanks!
  3. Remove Advertisements
  4. #2
    JP-ATS is offline Cadillac Owners Member
    Automobile(s): 2013 ATS 2.0T Performance AWD
    Oct 2013
    73
    Re: AC produces hot air from the passenger side - ATS 2.0T 2016
    Yes this is a very common problem, with no real fix unfortunately. The worst in my experience is when you need the warm air defroster to work in a snow storm to clear the windshield, but all that comes out is ice cold air when you have temp set to HI. I agree with you, very disappointing and embarrassing for Cadillac brand. The temp control problem has left a poor impression about the brand for many a passenger over the years, not to mention us drivers!
    RedCadi likes this.
  5. #3
    rsingl's Avatar
    rsingl is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 ATS 3.6 Premium RWD, 2016 Corvette Z06, 2018 GMC Sierra Denali 2500HD Diesel
    Sep 2007
    2,220
    I have no idea how and why GM screwed up something they have done so well for decades but they did so with the HVAC system in the ATS. I have owned numerous GM vehicles with automatic climate control since the late 1980s and the ATS is the only one with faulty operation. I haven't run into AC problems but for heat and defrost, depending upon the mood the system is in, I have to set commanded temperature to the upper 70s before it decides to add heat to a passenger cabin that is in the 40s and this is with a fully warmed up engine. I prefer keeping the passenger cabin cool (68 is perfect for me) but setting that temp in winter results in no heat even when a bottle of water is frozen in the cup holder after being parked outside for a few hours at a hotel. Other times the heater decides to cook the interior. With the ATS I often have to manually set the temperature and air delivery controls to force the automatic system to create the desired temperature which will be nothing close to what it would deliver with normal settings.
    My 2016 Corvette and 2018 GMC Sierra Denali have fully automatic climate control systems that work perfectly just like all of my previous GM vehicles AND they both provide real controls for their HVAC system so I don't have to play video games with their infotainment/nav systems in order to select specific climate control settings.
  6. Remove Advertisements
  7. #4
    oemtech's Avatar
    oemtech is online now Cadillac Owners Connoisseur
    Automobile(s): Charger Scat Pack- Auto/Corvette LS3-Auto
    Jul 2014
    Jarrell, TX
    2,326
    Quote Originally Posted by rsingl View Post
    I went thru this when I had my ATS. Of course the dealer answer was either NTF of can not reproduce the problem. At first they didn't believe me. That was until I showed them a video with my temp probe in the vents. OBTW - My temp differential was as high 20°+ some times and I had to change the temp as much as 5°+ below the cool set point to get them back in sync.
    My 08 Corvette HVAC auto climate control works as designed as does my the HVAC in the Scat. Love the front/rear vented seat feature in Scat especially on 100° days in Texas. Just wish I had it on the Corvette.
  8. #5
    May 2013
    57
    Thanks for responding. So if this is a common problem and they don't have a fix for it, isn't that considered to be a lemon car? Are there any lemon law lawyers on here? My car is still under warranty.
  9. #6
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    2,326
    Quote Originally Posted by ATS4EVER View Post
    Depends on what your state LL requirements are. GM will fight it... deep pockets and they will show engineering documents that say it is acceptable tolerances.
    Ex - Corvette fuel tank leak. 05 to 13. Obvious design and material issue. Extended warranty that is not a recall.. just a TSB. But, unless you know about it you're screwed. 10 years or 100k IIRC. But, it has to fail 2 GM tests. $1200 if it is on your dime.
    Sent from my LM-Q710.FG using Tapatalk
  10. #7
    RedCadi is online now Cadillac Owners Enthusiast
    Automobile(s): 2016 CTS 2.0 AWD Luxury
    Feb 2017
    Ohio
    782
    Same with CTS. I will never understand how Cadillac forgot what worked for decades.
    RonBaker likes this.
  11. #8
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    2,326
    Another example... Front seal leaking. GM calls it "SEEPAGE" and that is acceptable for GM but not me. It's not a leak until it drips.
    OBTW - They fixed my under warranty.
  12. #9
    Feb 2017
    Ohio
    782
    Quote Originally Posted by oemtech View Post
    Glad they honored the warranty for you. I often refer to my B2B tail light warranty.
  13. #10
    oemtech's Avatar
    Jul 2014
    Jarrell, TX
    2,326
    Quote Originally Posted by RedCadi View Post
    Only after I offered to park my car in the garage of my SA, the SA Mgr and the Shop Mgr after they took a good whiff under the hood when I brought it in for service.
    RedCadi likes this.
  14. #11
    Sydtron is offline Cadillac Owners Fanatic
    Automobile(s): 2013 ATS 3.6 Premium RWD
    Sep 2015
    Grand Rapids, MI
    36
    195
    I haven't had a run-too-hot yet, but since I had some repairs last summer (hit a deer) I get the blasts-ice-cold from the passenger vent about every other restart. From what I understand, they went from a physical sensor to a virtual sensor starting with the 2016's (I believe) - I wonder if my car got some updated software or a hardware version mish-mash that started causing the issue as I never had it in the years prior. Something to try, which temporarily fixes my issue, is to increase the temperature all the way up to "HI" and then all the way down to "LO", then back to whatever temperature you want - generally takes care of it until the next restart. Makes me wish for temp dials though, as holding the buttons takes like 10-15 seconds.
    RedCadi likes this.
  15. #12
    RudyF6 is offline Cadillac Owners Fanatic
    Automobile(s): 2016 ATS4 2.0T and a bunch of other stuff....
    May 2018
    In a holler on a lake, MI
    58
    316
    Mine went hot on the driver's side a few times last summer. Usually cured with a restart - what a pita. Never happens at the dealership.
    ATS4EVER likes this.
  16. #13
    Feb 2017
    Ohio
    782
    Nothing happens at the dealership. That's the tail light portion of our B2B.
    jeffbazell1 and RudyF6 like this.
  17. #14
    May 2018
    58
    316
    I'm sure they have a keyboard shortcut to enter "No problem found, unable to duplicate, yada yada..." on our repair orders.
    RedCadi and NewtPL36 like this.
  18. #15
    Feb 2017
    Ohio
    782
    Quote Originally Posted by RudyF6 View Post
    . . .no code, functions as designed, they all do it. Trade it in on a new Cadillac.
    ATS4EVER and RudyF6 like this.
  19. Remove Advertisements
Similar Threads
  1. 2008 Escalade produces cold air but fan does not blow?
    By dmay777 in forum Cadillac Escalade, EXT and ESV Forum - 2007-2014
    Last Post: 07-08-18, 10:26 AM
  2. STS 99 AC problem: Cold passenger side, Hot Driver Side
    By ben.gators in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 05-11-14, 08:46 PM
  3. Drivers side cold air, Passenger side HOT air
    By TURBO2 in forum Cadillac DeVille 1985 to 2005 including:
    1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
    Last Post: 09-13-13, 09:00 PM
  4. 06 DTS blowing cool air on the driver side and hot air on the passenger side.
    By dseebran in forum Cadillac DTS Forum - 2006 through 2012
    Last Post: 09-15-12, 04:42 PM
  5. Driver-side Cool Air/Passenger-side HOT air
    By danalex in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 12-18-10, 12:58 PM
Read about Lincoln | Buick | Genesis 70 Forum | Kia Forte Forum
