timing issue
Results 1 to 4 of 4
Cadillac Allante Forum Discussion, timing issue in Past Cadillac Vehicle Discussion; I have replaced the distributor with a new one, complete. I now have the timing set with a light to ...
    canukdon@outlook.com is offline Cadillac Owners Member
    Automobile(s): 1989 Allante
    Jul 2018
    Columbia,MO.
    10
    timing issue
    I have replaced the distributor with a new one, complete. I now have the timing set with a light to 12 DBTDC and it runs well, idle is about 750. Problem is when I shut it off, it will not start until I turn the distributor about 20 drees retarded and them slowly bring it to 12 again. This is with the wires in the obd reader port joined to enter timing mode,
    Seems I am doing it right but I cannot figure out why the timing needs to be moved to start it, is there something electrical that Should be doing it for me?
    Quick reply to this message Reply
    Ross_blk_93_Pa is offline Cadillac Owners Member
    Automobile(s): 1993 allante 91 allante
    Feb 2015
    north east Pa
    61
    99
    Re: timing issue
    check to see that your jumping the correct pins in the aldl
    Jul 2018
    Columbia,MO.
    10
    Re: timing issue
    The Aldl is jumped correct, I spent a couple hours timing it by ear at 750rpm and kept trying to start it. Other than set at about 30 degrees retard, it will not start, it runs good at this in the garage, have not driven it yet or pulled the jumper out to see where the timing ends up. I am wondering if I put the new distributor in one tooth out of place? Would that show it off that much but still run good?
  5. #4
    Feb 2015
    north east Pa
    61
    99
    Re: timing issue
    No once you set it you have to remove the jumper wire or it will stay in base timing mode. with the jumper removed the timing can be checked thru the on board diagnostics usually reads 25 btc. ecm data will get you to the timing reading.
Similar Threads
  1. Can you set the timing on a 2009 CTS 3.6DI without removing the timing chain covers?
    By 09silvercts in forum 2008-2013 Cadillac CTS General Discussion
    Last Post: 10-11-16, 11:00 PM
  2. 2.0T timing belt or timing chain?
    By mdoaw12i in forum Cadillac ATS General Discussion Forum
    Last Post: 08-27-14, 10:29 PM
  3. need help 07 2.8 timing cover removal and timing chain replacement
    By tom70 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 06-03-13, 06:00 PM
  4. 1989 Brougham timing tab or timing pointer
    By cadillac1989 in forum RWD 19xx-1984 DeVille and Fleetwood,
    1985-1996 Fleetwood and Brougham Forum
    Last Post: 03-05-12, 02:43 PM
  5. Replies: 1
    Last Post: 08-20-06, 02:26 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
