rebuilding 2014, Headlight issues
Results 1 to 3 of 3
2014+ Cadillac CTS General Discussion Discussion, rebuilding 2014, Headlight issues in Cadillac CTS Third Generation Forum - 2014+; I am rebuilding a 2014 new style headlights and fender car, when i bought it it needed the font replaced ...
    kbls6305 is offline Cadillac Owners Member
    May 2019
    Question rebuilding 2014, Headlight issues
    I am rebuilding a 2014 new style headlights and fender car, when i bought it it needed the font replaced including the driver side headlamp assembly and the connector plug rewired to the wiring harness, I purchased the headlamp and the plug from ebay and had the plug pinned and wired to the harness matching the passenger side. when the light was in place and turned on the led day time running lights are amber in color, the same as the turning signals on the bottom fog lights when signal is on or emergency flasher, the passenger side drl never turn an amber color, they are always clear. This is an ebay light so i thought the module/ballast could be wring, or the bulbs if that is possible. could it be a wring issue? is amber drl even an option in any headlamp like this? Any input or suggestion is appreciated.
    Thanks
    May 2019
    Re: rebuilding 2014, Headlight issues
    Denrael's Avatar
    Denrael is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 CTS Vsport
    Apr 2015
    SC Kansas
    836
    Quote Originally Posted by kbls6305 View Post
    Thanks
    Don't have an absolute solution, but can tell you the DRL's are always clear/white. But you also have another issue... Why aren't the vertical portion (below the headlamp) of the DRL's lit? They should be on any time the upper DRL's are on, turning amber on the vertical portion during flasher/blinker operation. My guess... this is probably a wiring problem.
Similar Threads
  1. Just Bought a 2014 SRX from a Caddy Dealer, Headlight Issues
    By Dabman in forum Cadillac SRX Second Generation Forum (2010-2016)
    Last Post: 01-30-19, 10:44 AM
  2. 2014 Cadillac CTS 3.6 vs. 2014 Audi A6 3.0T, 2014 BMW 535i xDrive, 2014 Mercedes-Benz
    By ep_83 in forum 2014+ Cadillac CTS General Discussion
    Last Post: 12-06-13, 09:33 PM
  3. Rebuilding a Northstar engine
    By BeelzeBob in forum Northstar Engines and System Technical Discussion
    Last Post: 06-09-06, 04:34 PM
  4. rebuilding '78 Fleetwood limo
    By Limodriver in forum RWD 19xx-1984 DeVille and Fleetwood,
    1985-1996 Fleetwood and Brougham Forum
    Last Post: 05-06-04, 01:37 PM
  5. Rebuilding my Northstar please help!
    By eldoradoescobar in forum Northstar Engines and System Technical Discussion
    Last Post: 08-30-03, 05:45 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
