Stock rear differential strength
Results 1 to 14 of 14
Like Tree8Likes
  • 1 Post By Long
  • 2 Post By Joseph Upson
  • 1 Post By Joseph Upson
  • 1 Post By Long
  • 3 Post By jayoldschool
2008-2013 Cadillac CTS Performance Mods Discussion, Stock rear differential strength in Cadillac CTS Second Generation Forum - 2008-2013; Guys, how much HP/torque can the stock rear differential handle before it needs upgraded to the cast iron V diff. ...
    Big_kid is offline Cadillac Owners Member
    Automobile(s): 08 CTS 3.6 PFI
    Oct 2013
    Northern indiana
    52
    46
    Also did the stock V6 diff ever come in (G80) limited slip.
    kkuz is offline Cadillac Owners Connoisseur
    Automobile(s): CTS 2008 3.6DI Sport Luxury
    Sep 2014
    Europe
    1,027
    Re: Stock rear differential strength
    LSD comes with Performance package.
    Long's Avatar
    Long is offline Cadillac Owners Master
    Automobile(s): '89 Coupe deVille 4.5L V8, '10 CTS4 3.6L DI Performance/Luxury sedan
    Jan 2017
    Central New York
    44
    5,944
    Not all performance pkg Gen II CTS' came with SPID G80.
    Buyer beware.
    silversport likes this.
  5. #4
    Padgett's Avatar
    Padgett is offline Cadillac Owners Enthusiast
    Automobile(s): '11 CTSC & several other cars.
    Sep 2018
    Orlando
    878
    Personally would rather have a 3.23 than the 3.73. Would like to be under 2k rpm at 70 mph. Mine has the aluminum case and LSD. Were other ratios available with G80 ?
  6. #5
    Joseph Upson is offline Cadillac Owners Enthusiast
    Automobile(s): 08 CTS DI
    May 2006
    FL
    988
    Quote Originally Posted by Padgett View Post
    3.42, which would put you right at ~2100. I believe the 3.73 is likely only mated to the manual transmission, although at ones request the 3.73 might have been available for the auto, I doubt it given how short first gear would be, not to mention the associated fuel "noconomy".
    I looked this subject up some time ago and arrived at the conclusion likely from GMParts based on what was offered that the 3.23, 3.42 and 3.73 were the only options available to the second gen. I lifted the info below from a GM pdf so not all listed were options.
    https://d354nuoz4t18d4.cloudfront.ne...?cb=1543219590
    GU1 AXLE,REAR,2.41 RATIO
    GU2 AXLE,REAR,2.73 RATIO
    GU3 AXLE,REAR,2.93 RATIO
    GU4 AXLE,REAR,3.08 RATIO
    GU5 AXLE,REAR,3.23 RATIO
    GU6 AXLE,REAR,3.42 RATIO
    GT4 AXLE,REAR,3.73 RATIO
    wcthunder and CaddyFred like this.
  7. #6
    wcthunder's Avatar
    wcthunder is online now Cadillac Owners Connoisseur
    Automobile(s): 2014 CTS Coupe 3.6 RWD Perfomance Pkg, TriCoat White Diamond
    Jan 2012
    Philly Suburbs
    1,143
    Quote Originally Posted by Joseph Upson View Post
    I have GT4. Good info!
  8. #7
    May 2006
    FL
    988
    Quote Originally Posted by wcthunder View Post
    It should come off the line like fire if it's an automatic.
    Here is some more valuable info;
    Steering ratio:
    FE2 RWD: 15.5
    FE2 AWD: 16.17
    FE3 RWD: 15.4
    Steering turns, lock-to-lock:
    FE2 RWD: 2.6
    FE2 AWD: 2.8
    FE3 RWD: 2.5
    Turn circle (ft / m):
    FE2 RWD: 37.47 / 11.42
    FE2 AWD: 38.98 / 11.88
    FE3 RWD: 36.75 / 11.20
    CaddyFred likes this.
  9. #8
    Long's Avatar
    Jan 2017
    Central New York
    44
    5,944
    All RWD coupes got GT4, 3.73 axle ratio.
    TheFlash likes this.
  10. #9
    Padgett's Avatar
    Sep 2018
    Orlando
    878
    Interesting. Really makes me wonder what demographic group they were aiming for. Last car I recall that came with a 3.73 was the 1st gen Z-28 Camaro.
  11. #10
    jayoldschool's Avatar
    jayoldschool is offline Super Moderator
    Automobile(s): 2011 CTS SportWagon
    Sep 2006
    Ontario, Canada
    46
    9,263
    Not you, lol
    silversport, HurstGN and CaddyFred like this.
  12. #11
    acstudios is online now Cadillac Owners Fanatic
    Automobile(s): 2008 CTS Black Raven Sedan / LY7 / 6 Speed Manual AY6 / RWD
    Jul 2014
    SE Ontario
    45
    248
    I have a G80/GU6 mated to my POS AY6 gear grinder.
  13. #12
    May 2006
    FL
    988
    Probably not a demographic thought at all. The coupe looks faster than the sedan and 3.73 gears should leave no question about that suspicion, because it should be. That's probably where your missing fuel economy is. I have the 3.42 ratio and if I ever bump the power up enough to justify it I'd probably trade them for the 3.23 for an mpg bump along with the additional power.
  14. #13
    Padgett's Avatar
    Sep 2018
    Orlando
    878
    Well first gear is probably more than many can handle, particularly with posi. I have one merge lane that visibility back on the 45mph through road is nill (underpass butresses) until you get almost to the end of the lane so have to be at a creep or stop then accelerate hard in a 30 degree angle to merge. If any Florida ice has dropped, it can be interesting (why wet traction is so important to me & want rear tires with a contact patch I can load without relying on fractals)
  15. #14
    wcthunder's Avatar
    Jan 2012
    Philly Suburbs
    1,143
    I have GT4, Steering ratio: FE2 RWD: 15.5, Steering turns, lock-to-lock: FE2 RWD: 2.6, Turn circle (ft / m): FE2 RWD: 37.47 / 11.42...Not concern what all models have...
Similar Threads
  1. Poor strength on rear hatch struts
    By philly88 in forum Cadillac XT5 First Generation Forum (2017+)
    Last Post: 01-31-19, 03:01 PM
  2. Piston strength
    By shade in forum 2009-2015 Cadillac CTS-V General Discussion
    Last Post: 06-03-10, 05:15 PM
  3. Aftermarket Wheel Strength
    By Yaemish in forum Cadillac Seville / Cadillac Eldorado Forum
    Last Post: 04-10-07, 12:42 AM
  4. Altenator Strength
    By MikeyVSeries in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 04-14-05, 09:02 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
