Diff fluid changes
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree4Likes
2008-2013 Cadillac CTS General Discussion Discussion, Diff fluid changes in Cadillac CTS Second Generation Forum - 2008-2013; Planning to change the front and rear diff fluid soon, the juddering while turning in a parking lot sucks. Do ...
    naiku is online now Cadillac Owners Fanatic
    Automobile(s): 2012 CTS Sport Wagon Premium/Performance
    Jul 2018
    170
    Planning to change the front and rear diff fluid soon, the juddering while turning in a parking lot sucks. Do I add the limited slip additive to the front and rear? Or just the rear?
    I have the G80 option code, want to make sure I get everything I need. And I really really to get rid of the awful judder at low speed turns.
    Just realized it's the transfer case that causes the shudder, what's needed to eliminate that?
    Thanks.
    Long's Avatar
    Long is offline Cadillac Owners Master
    Automobile(s): '89 Coupe deVille 4.5L V8, '10 CTS4 3.6L DI Performance/Luxury sedan
    Jan 2017
    Central New York
    44
    5,950
    Re: Diff fluid changes
    There are some good step by step how-to's in the DIY/FAQ thread.
    Jul 2018
    170
    Quote Originally Posted by Long View Post
    Spent some time reading those last night, it's how I realized it's the transfer case that causes the juddering. Trying to find somewhere closer than an hour's drive from me that carries 3/8" key stock to make the little tool for the transfer case fill plug.
  5. #4
    CaddyFred's Avatar
    CaddyFred is offline Cadillac Owners Enthusiast
    Automobile(s): '09 CTS DI FE1 Luxury
    Sep 2018
    PA
    665
    I have RWD so I haven't read anything about servicing the transfer case but would these work?
  6. #5
    Jul 2018
    170
    The dimensions listed don't quite make sense .... 5.8 x 2.7 x 0.8 inches but even the smallest one of those 0.8" by the time you add in the ratchet head will be too big. In this thread there is a picture showing that the 3/8" square key works best when cut to just under an inch. Assuming that bit on Amazon is 0.8" then you would need the ratchet head to be 0.2" thick at the absolute most.
  7. #6
    Padgett's Avatar
    Padgett is offline Cadillac Owners Enthusiast
    Automobile(s): '11 CTSC & several other cars.
    Sep 2018
    Orlando
    888
    Haven't tried the caddy but on other GM cars I just use the end of a 3/8 extension without a socket.
    AndyT3 likes this.
  8. #7
    Long's Avatar
    Jan 2017
    Central New York
    44
    5,950
    Quote Originally Posted by Padgett View Post
    There's no room.
    Try a pass through ratchet.
  9. #8
    Jul 2018
    170
    There's no room.
    I picked up some 3/8" square key stock yesterday, just need to cut a small piece off. I'm hopeful the fill plug is not too tight that I can just get a wrench onto the square with it inserted in the plug.
    Just waiting on all the fluids to be delivered before I make a start. If I remember I may take some pictures to add to the DIY threads.
    HurstGN and KirkEllis like this.
  10. #9
    Long's Avatar
    Jan 2017
    Central New York
    44
    5,950
    Quote Originally Posted by naiku View Post
    Good luck. More pics would be beneficial.
  11. #10
    Lifespeed is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS 3.6L DI rebuilt to FE3 J55 G80 3.42:1
    Dec 2017
    San Jose, CA
    51
    553
    I can't remember the details from a few months back, but I know I just used regular hand tools and didn't have to make anything.
  12. #11
    jayoldschool's Avatar
    jayoldschool is offline Super Moderator
    Automobile(s): 2011 CTS SportWagon
    Sep 2006
    Ontario, Canada
    46
    9,267
    GM additive, rear diff only. No G80 up front ;-)
  13. #12
    CaddyFred's Avatar
    Sep 2018
    PA
    665
    I had no idea it was that tight around the fill plug. Glad you got what you needed to do the job.
  14. #13
    KirkEllis's Avatar
    KirkEllis is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS4
    Aug 2014
    Chicago, IL
    180
    Was told by an ASE tech (while in the Cadillac service area) to add the limited slip front & rear to help with the judder you are experiencing.
  15. #14
    Jul 2018
    170
    Quote Originally Posted by KirkEllis View Post
    I've read that somewhere else as well, but the majority say to use the additive in the rear and the anti shudder in the transfer case. By this time next week I should know, fluids should be here Monday so I may try to find time Tuesday evening to swap them out.
    KirkEllis likes this.
  16. #15
    redheadedrod is offline Cadillac Owners Connoisseur
    Automobile(s): '12 CTS Performance Sports Wagon AWD
    Jan 2016
    Western Michigan (Near GR)
    2,106
    For the transfer case I found it easy to just lower the transmission mount to gain access to the fill port. I left the bolts away from the transfer case in just a few threads for alignment when reassembling, the two bolts by the transfer case I totally removed using a floor jack to hold the transmission mount...
    Did not have to remove anything else and was able to EASILY change and refill the transfer case. I also had the serpentine belt removal tool which make it much easier than other methods.
Similar Threads
  1. 2017 Changes - ATS V and CTS V - Does Anyone If There Are Any Changes Coming
    By caddyhills in forum Cadillac ATS-V Series Forum
    Last Post: 06-16-16, 08:19 PM
  2. Diff Fluid change using GM Fluid and LSD additive
    By SupertreyG in forum 2004-2007 Cadillac CTS-V Performance Mods
    Last Post: 12-13-14, 03:08 PM
  3. High-temp brake fluid? diff fluid?
    By Jinx in forum 2009-2015 Cadillac CTS-V Performance Mods
    Last Post: 02-27-14, 10:27 AM
  4. Trans Fluid/ Diff Fluid
    By 6 SPEED Z in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 01-19-09, 02:45 PM
  5. First diff fluid change, pics of that and diff bushing (i think??)...
    By CTSV_510 in forum 2004-2007 Cadillac CTS-V Performance Mods
    Last Post: 08-05-08, 01:57 AM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
