Engine clicking normal?
Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By Long
2008-2013 Cadillac CTS General Discussion Discussion, Engine clicking normal? in Cadillac CTS Second Generation Forum - 2008-2013; I just purchased a 2012 CTS Performance coupe with 80k. I’ve noticed a clicking sound coming from the engine that ...
    TooOldToDrive is offline Cadillac Owners Member
    Automobile(s): 2012 CTS coupe
    Mar 2019
    Minnesota
    6
    I just purchased a 2012 CTS Performance coupe with 80k. I’ve noticed a clicking sound coming from the engine that I’ve not heard in my previous cars. What should I check?
    Long's Avatar
    Long is offline Cadillac Owners Master
    Automobile(s): '89 Coupe deVille 4.5L V8, '10 CTS4 3.6L DI Performance/Luxury sedan
    Jan 2017
    Central New York
    44
    6,057
    Re: Engine clicking normal?
    It is most likely the ticking associated with direct injection. This sound is normal.
    FunkZ and njlotito like this.
    ptorto is offline Cadillac Owners Member
    Automobile(s): 2009 CTS4
    Oct 2015
    West of Chicago
    25
    I have a 2009 (3.6) with less than 70K and has a rattling sound when it starts, same issue? Also, the CEL has been on for a while, is this a timing chain issue?
  5. #4
    Long's Avatar
    Jan 2017
    Central New York
    44
    6,057
    Quote Originally Posted by ptorto View Post
    Get your CEL codes read.
  6. #5
    tinman's Avatar
    tinman is online now Cadillac Owners 10000+ Posts
    Jul 2006
    Jacksonville, Florida
    13,196
    Quote Originally Posted by TooOldToDrive View Post
    Agree with Long, a result of Direct Injection. Perfectly normal.
  7. #6
    Padgett's Avatar
    Padgett is online now Cadillac Owners Connoisseur
    Automobile(s): '11 CTSC & several other cars.
    Sep 2018
    Orlando
    1,026
    On a 3800 a clatter at idle/low speed is often a failing harmonic balancer .Just a thin band on my 3.6 but worth checking.
  8. #7
    Oct 2015
    West of Chicago
    25
    Had the CEL checked......the code came back "P0008 Engine Positioner System". Does this mean the timing chain(s) (at 66K) need to be replaced? Also, from what I've read there appears to be some bad mojo associated with this engine.....what advise can you give? Thanks.
  9. #8
    tinman's Avatar
    Jul 2006
    13,196
    Most probably, but you had better post up in the correct forum. Those folks will help you out in the '05 area. Be sure to let them know what engine you have. That just might help. Maybe.
  10. #9
    Oct 2015
    West of Chicago
    25
    Thanks, thought I was in the 08-13 CTS general discussion forum?
  11. #10
    tinman's Avatar
    Jul 2006
    13,196
    You are. I was looking at your avatar which says you have a 2005 CTS.
  12. #11
    Oct 2015
    West of Chicago
    25
    Oh, sorry, that was my other CTS. I just changed the profile info. Hey TooOldToDrive, sorry for hijacking your post. I'll start another thread under my issue for help. Thanks
  13. #12
    jeff10011 is offline Cadillac Owners Member
    Mar 2019
    3
    My 2009 CTS AWD DI makes the same noise. As others have said it is related to direct injection and normal.
    Cheers!
Similar Threads
  1. Clicking noise coming from Throttle Position Sensor -- is this normal?
    By jimsimm1 in forum Cadillac CTS First Generation Forum - 2003 - 2007
    Last Post: 06-26-15, 02:36 AM
  2. Is this noise normal and is the normal side to side play in the stock shifter bushing
    By texasseville in forum 2004-2007 Cadillac CTS-V General Discussion
    Last Post: 10-18-11, 06:08 PM
  3. Heater...normal or not normal?
    By outsider in forum RWD 19xx-1984 DeVille and Fleetwood,
    1985-1996 Fleetwood and Brougham Forum
    Last Post: 11-04-10, 09:35 PM
  4. Do you think this hp/boost is normal (within normal specs)?
    By snzuloz in forum 2009-2015 Cadillac CTS-V General Discussion
    Last Post: 10-21-10, 03:45 PM
  5. Loud clicking from catalytic converter heat shield...normal???
    By WaterSun in forum Cadillac Escalade, EXT and ESV Forum - 1999 - 2006
    Last Post: 01-28-08, 09:42 PM
Read about Lincoln | Buick | Genesis | Kia Forte Forum
