02 ESCALADE EXT 140K DTC p0200 & p0307 questions
Results 1 to 2 of 2
Vortec 6.0 / 6.2 Liter Discussion, 02 ESCALADE EXT 140K DTC p0200 & p0307 questions in Cadillac Engine Discussion; I am getting codes p0307 and p0200. I know normally you would start with the highest dtc first P0307 would ...
    Ragtp66 is offline Cadillac Owners Member
    Automobile(s): 2002 Escalade EXT
    Feb 2014
    44
    4
    I am getting codes p0307 and p0200. I know normally you would start with the highest dtc first P0307 would be cylinder misfire on cylinder #7 I dont visually see a broken plug wire or that it rubbed on anything. I will try wetting the wires and look for arcing and pull the plug. I am curious though as the P0200 I am thinking is more injector related which if it was dirty or shorted would throw the 200 and then also the p0307. I will try to ohm the injector and check with a noid light for pulses in the morning. It does have a stumble from idle when accelerating at idle feels like it may stall but hasnt yet. I will probably end up doing a full tuneup. Plugs wires fuel and air filters. I am thinking it may not be a bad idea to pull the injectors and have them sonic cleaned and flow tested. If anyone has any other suggestions please let me know.
    Thanks
    Chris
    BMWUTAH is offline Cadillac Owners Member
    May 2014
    Swap plug/wire/coil. Swap inj. If problem moves address defective part. GM does not recommend Sonic clean.
