Results 1 to 4 of 4
    AJxtcman is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: Member of Air Fuel Tuning (Cadillac Division)
    Apr 2007
    Inside The Northstar PCM
    42
    2,533
    03 6.0L test question
    I missed this question a few years back on a semi annual exam.
    The question read some thing like this.
    On an 03 Escalade is the pistons OD bigger than the Cylinders ID?
    I got it wrong.
    The information is stated in the following area.
    New Product Information
    The purpose of New Product Information is to highlight or indicate important product changes from the previous model year.
    Changes may include one or more of the following items:
    • Torque values and/or fastener tightening strategies
    • Changed engine specifications
    • New sealants and/or adhesives
    • Disassembly and assembly procedure revisions
    • Engine mechanical diagnostic procedure revisions
    • New special tools required
    • A component comparison from the previous year
    Disassembly and Assembly Procedure Revisions
    • For certain applications, a spacer plate has been added between the flywheel and rear of the crankshaft. It is necessary to remove the spacer plate prior to removal and installation of the crankshaft rear oil seal and clutch pilot bearing.
    • The piston, pin, and connecting rod are to be serviced as an assembly.
    • Newer design pistons have a graphite coated piston skirt. The coated skirt outside diameter (OD) may be slightly larger than the cylinder bore inside diameter (ID) and the piston assembly may have a slight interference fit to the cylinder bore during initial installation.
  2. Cadillac Network Advertisements Registered members do not see these ads. Click here to remove them.
    Always
    Advertising world
    2010
    Many
    Apr 2007
    42
    2,533
    Re: 03 6.0L test question
    The second test this year had a question about an 8.1L in a 2007 GMC Truck Sierra Classic. Is the piston OD bigger that the cylinder ID. I was not going to miss this one. We sure have come along way from the old TRW pistons that had .0066 clearance
    GM info
    The piston skirts are coated in order to create an interference fit into the cylinder bore.
    Important: The coating on the piston allows for an interference fit between the cylinder and the bore. The piston diameter can NOT be measured accurately because the piston coating is not a consistent thickness. DO NOT measure the piston diameter.
    To select the correct piston for installation, the cylinder bore must be measured. If the cylinder bore diameter is within service specifications, install the original piston/connecting rod assembly or a new, standard size piston/connecting rod assembly. A used piston/connecting rod assembly may be installed if, after cleaning and inspection, the piston is not damaged. If the cylinder bore is NOT within specifications, the cylinder must be resized to accept a new, oversized piston.
    For proper piston fit, the engine block cylinder bores should not have excessive wear or taper.
    dkozloski's Avatar
    dkozloski is online now Cold Soaked Cadillac(s) I Drive: 2006 STS AWD, '95 Ford Ranger
    Jul 2004
    Fairbanks, Ak
    70
    19,958
    Two-stroke motorcycles are very critical for cylinder to piston clearance. I measured the clearance during a rebore operation by inserting the piston in the cylinder with a long feeler gauge at 90 degrees to the piston pin. Then I'd use a spring scale to measure how much force it took to withdraw the feeler gauge. I handled the piston and cylinder using gloves and/or shop towels to minimize heat transfer.
    Don't mess with Binky Bear!
  5. Sponsored Cadillac Advertisements (Supporting Members don't see these ads):
    z06bigbird is offline Cadillac Owners Connoisseur Cadillac(s) I Drive: Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,585
    Quote Originally Posted by dkozloski View Post
    When you worked on the cylinders, did you polish them to a mirror finish? My uncle had a H D dealership, and he used to remind me to make sure that the cylinders (at least on the 2 cycle) bikes had a mirror finish. Greater speed, less heat, I guess.
    Just curious.
Simply register and/or login to remove these advertisements.
  • You may not post replies
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum | kia forte forum | used car savings
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
