Bent valves
Results 1 to 2 of 2
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, Bent valves in Cadillac Engine Discussion; I have a 2007 STS 3.6 , 103000 miles, last Feburary when i go down to -13 deg, went to ...
    Theduck is offline Cadillac Owners Member
    Automobile(s): 2007 sts
    Feb 2014
    65
    3
    Bent valves
    I have a 2007 STS 3.6 , 103000 miles, last Feburary when i go down to -13 deg, went to go to work car would not start, jump forward all intake valves on passenger side bent, my question is what was the cause of failure, car ran, when it was taken apart the timing chain was loose on that side, need to pull other head as compression was below specs on that side also. Just wondering what course of action i need to take, any help would be appreciated.
    Acdcpsp is offline Cadillac Owners Fanatic
    Automobile(s): 2008 CTS4 3.6 LY7
    Feb 2013
    236
    Re: Bent valves
    Timing Changes in the earlier versions of the 3.6 are known for developing slack. This can happen when the oil level becomes lower from it burning oil and the tensors not having enough oil pressure to keep the correct tension.
