Rear main seal replacement?
Results 1 to 2 of 2
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, Rear main seal replacement? in Cadillac Engine Discussion; Last weekend I was told by a shop that my rear main engine seal is leaking and would need to ...
    GCTS1 is offline Cadillac Owners Member
    Aug 2012
    17
    Last weekend I was told by a shop that my rear main engine seal is leaking and would need to be replaced. I was told that they would need to drop the transmission in order to access and replace that seal... Is this true? I know that on other vehicles the rear main seal can be replaced by removing the oil pan without having to remove the transmission.
    By the way I have a 2004 CTS with the 3.6L engine.
    calif phil is offline Cadillac Owners Enthusiast
    Automobile(s): 2014 ATS
    Jan 2013
    Kansas
    512
    Modern vehicles have a one piece rear seal and you do need to drop the transmission to replace
    I would look at the valve covers to make sure what's leaking by the rear seal is not running down from above.
