2003 CTS 80000 miles runs rough only at idle
Results 1 to 10 of 10
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, 2003 CTS 80000 miles runs rough only at idle in Cadillac Engine Discussion; I have a 2003 cadillac cts that misfires 1, 3, 5 cyl when at idle. Codes are p0300 p0301 p0303 ...
    caleb is offline Cadillac Owners Member
    Automobile(s): cts
    Sep 2013
    52
    4
    I have a 2003 cadillac cts that misfires 1, 3, 5 cyl when at idle. Codes are p0300 p0301 p0303 p0305. These are my only codes, so far changed plugs, swap coils, inspected v/c gaskets and spark plug wells no oil leakage. Check wiring, vacuum lines associated with 1 3 5 bank no problems or leaks. Compression good no antifree leaks. Went and got gm fuel inj cleaner from dealer no change. I use 91 octane only. Car has great power, speed, and acceleration. No trouble starting, starts up everytime no problem. Note: idle good first thing in morning when its first started until car warms up then it runs rough. Rpms go from 800 smooth rpms to 600 rough rpms in the am. Stays at 600 after warming up with a rough idle.
    Any suggestions running out of ideas, but I bet its something right under my nose I'm missing. Timing belt done at 60000. Problem started right after getting gas 1 1/2 weeks ago.
    lukes03cts is offline Cadillac Owners Member
    Automobile(s): CTS
    Oct 2013
    Re: 2003 CTS 80000 miles runs rough only at idle
    Caleb, If i could describe what was happening to my car it would be almost exactly what is happening to yours. One thing to add is that I went to the dealer to
    get the idle raised which was suggested on this forum. It didn't help. As soon as I started driving the damn check engine light came on again for misfires on 1 3 and 5 . So I brought the car back to the dealer and they determined the intake manifold gasket was installed incorrectly when I did the timing chain. They checked the timing marks which were correct. And they said I had the wrong plugs in there so that could be a culprit. I had them put the proper plugs in and also fix the gasket. But to disappointment this problem still persists. I am at my wits end. Next is the coil pack switcharoo . I understand that these engines idle like shit and there is no fix for that. I even took the pedal apart and put a shim in the pedal with a lego from my kids . That worked for a day then the pedal went crazy and now doesn't work. I ordered a new pedal . This is by far the worst car I have ever owned. I cannot believe how many electrical and mechanical problems I have had with this cts.
    I dont care if it idles like shit but having a check engine light come on all the time is absolutely unacceptable to me.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    When was the TB last cleaned?
    Automobile(s): CTS
    Oct 2013
    Just did a throttle body cleaning . Still running like crap . I reset the ECM codes tried again & still flashing CEL with misfire on 1 , 3 & 5 .
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,833
    Plugs? LY7 is a hard engine to do plugs on, have to remove the intake manifold and lukes has posted some good info as well.
    Edi
    Edi is offline Cadillac Owners Member
    Automobile(s): CTS 3.2 2003 Auto
    Dec 2011
    43
    1
    caleb and lukes, I have been heavily chasing this damn problem in my 03 CTS since 1.5 years now , car has done 75K miles and started at 60K, I have done exactly what you guys have done and seen all what you described. then stopped . recently the RH side catalyst blasted out as a result so I went I changed all gaskets then replaced both catalysis with magnaflow free flow and CAT back ( I'm doing some tuning as well ) .I still get p0300 p0301 p0303 p0305. The car has gained more horse power but this is still irritating me so much!.
    I have scanner and proper tools, I went and followed some service manuals ; I can only suspect something common in between 3 of them 1,3 and 5. One mostly will start the misfire cycle and move to the next one as I have seen on the scanner .
    I cleaned fuel tank and fuel lines and changed fuel filter; had the injectors cleaned at service center and upper Throttle body plus Air intake caskets been changed and cam cover gaskets and bolts ring for the cover.
    I'm now convinced it has nothing with fuel air mixture and it has to be some damn electric issue ; I would say either a harness problem which is really so difficult to trace Or the ECM it self is not properly igniting at low rpms for that side.
    I'm now more determined to chase it to the end ; as I already spent a lot and tried few mechanics who just took money and did nothing! so I will do it my self. just ordered and new ecm and will have it programmed then will check and let you know how it goes. I might also check and change the lower Air intake gaskets ( Flange ) though its a pain in the ass .
    will post result once i reach into something.
    SC2150's Avatar
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,833
    Injector issue then is where I am at...especially as you state the cat failed (sure sign of a stuck injector flooding fuel in that bank).
    At idle, try disconnecting one coil at a time to see if one does not cause the idle to drop and that is the cylinder to blame. Try replacing that injector then and I am willing to bet your problem goes away.
    gavagni1 Guest
    have the same problem with my cadillac cts 2004 with 85000 miles i have error codes p0300,p0301,p0302,p0303
    moncelismo is offline Cadillac Owners Member
    Jan 2014
    3
    eddie did you change the ecm ? and how did worked ?
    Jan 2014
    3
    Quote Originally Posted by gavagni1
    I know exactly what it is. Just fix mine codes P0300 , P0301 , P0303 , P0305. Bank 1 cylinders 1,3 and 5 not working. It was driving me crazy until I check the last thing (fuses). Just a 15 amp fuse under the hood coil/ inj. I save $700 that somebody was charging me. Thank's God. I hope I can help somebody in the same situation.
  13. Remove Advertisements
