oil leak
Results 1 to 6 of 6
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, oil leak in Cadillac Engine Discussion; I have a 2003 3.2 that has developed a very slight oil leak on the driver side of the engine. ...
    malibured is offline Cadillac Owners Member
    Automobile(s): 2003 cts
    Jan 2012
    Lubbock,TX
    1
    oil leak
    I have a 2003 3.2 that has developed a very slight oil leak on the driver side of the engine. Just looking for any info on this before I tear into it. Has anyone had this problem?
    CadyTech4Life is offline Cadillac Owners Member
    May 2013
    17
    Probably leaking from camshaft covers. I would recommend replacing with new cover and gasket. Usually the old ones warp and will still develop leak if you only change gasket.
    713CTS is offline Cadillac Owners Member
    Automobile(s): cts
    May 2013
    30
    8
    I had an oil leak that was a 7 dollar fix. It was the oil sensor switch which is in the lower front of the engine. It made a mess everywhere so it took me a little while to find, but worth checking! I have the same car
    69 Camaro's Avatar
    69 Camaro is offline Cadillac Owners Member
    Automobile(s): '04 SRX 3.6 AWD, 69 Camaro, 98 Yukon
    Apr 2012
    Cheyenne, Wyoming
    95
    Re: oil leak
    I have a leak but it looks to be coming from below the oil filter canister. It would be nice to find because I am going through a qt o f oil every 800 miles and it leaves drips were ever I park it.; It's in the garage now sitting over a piece of cardboardl. You're not talking about the oil pressure sending unit under the filter are you? That's not where mine is leaking. Cant see anything from under the hood. but plenty of oil dripping off the drivers side of the oil pan. It's the 3.6 in an 06 SRX.
    w
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    31
    383
    Re: oil leak
    CTS 3.2
    front bottom part of the engine is covered in oil, all over the oil pan and actual dripping oil from the top oil filter housing, not sure if it's all coming from the front or from the valve covers possible.
    I'll do the valve covers first and see where it takes me
    CaddyObsessed is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac SRX V6 RWD
    Jan 2009
    3 Hours from Santa!
    25
    I just fixed an oil leak on my 2005 SRX with the 3.6 V6. Under the car I unbolted and moved the AC compressor out of the way. The base of the oil filter adaptor has 4 bolts and it also has one bolt accessible from the top of the engine. All 4 lower bolts were loose. Like finger tight only/ barely. Torqued them all properly and leak is fixed. Reinstall compressor.
  9. Remove Advertisements
