How to Clean The PCV tube on 05' CTS 3.6 - Page 2
Closed Thread
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, How to Clean The PCV tube on 05' CTS 3.6 in Cadillac Engine Discussion; You wont quit will you.....all catchcans are not the same, and no catch can causes fuel dilution...it is impossible, RX ...
  1. #16
    SC2150's Avatar
    SC2150 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Feb 2012
    Palmetto, FL
    60
    1,825
    Re: How to Clean The PCV tube on 05' CTS 3.6
    You wont quit will you.....all catchcans are not the same, and no catch can causes fuel dilution...it is impossible, RX or other.
    I think his pictures show pretty much "real world" and the fact that this is what we do....build and rebuild engines, and every picture except yours shows the gunk build-up.
    The gunk buiuldup is caused by the oil ingestion.....trap the oil before it is ingested and you have no buildup plain and simple.
    And it has been pointed out over and over again "NO FUEL TOUCHES the intake side of the valves where the gunk deposits form.....so it does not matter what fuel is used on DI motors. The fuel is introduced directly into the combustion chamber on the only in the combustion chamber for a milisecond. For a top tier fuel, or fuel additive to have any effect on keep valves clean it has to be a port injected or carburated engine where the aitr/fuel mixture passes the intake side of the valves allowing it to contack the sureface where the deposits form.
    Quick reply to this message Reply
  2. #17
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    OP asked for ideas how to clean his PCV. He didn't ask for romper room.
    SC2150, and ktr-sb; if you two children cannot play nice, you will both be gone.
  3. Remove Advertisements
Closed Thread
