Could Sensors Be The Problem
Results 1 to 5 of 5
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, Could Sensors Be The Problem in Cadillac Engine Discussion; Is It Possible For Sensors Tho Make My 2003 Cts Stall......is This Possible, I Stall And In 10 In I ...
    italiantnt is offline Cadillac Owners Member
    Nov 2004
    16
    Is It Possible For Sensors Tho Make My 2003 Cts Stall......is This Possible, I Stall And In 10 In I Start Right Up..i Dont Get It
    Mbai2's Avatar
    Mbai2 is offline Cadillac Owners Connoisseur
    Automobile(s): 2017 CTS-V
    Aug 2003
    1,654
    Re: Could Sensors Be The Problem
    I would check for any corroded wiring. If wires are shorting or disconnecting that have to do with the ECM keeping the engine running, stalling would indefinately occur. The point of corrosion will be hard to pinpoint though.
    I remember a while back that a car (can't remember which model) had wiring that rubbed against the door hinge everytime it was opened and shut. Eventually the insulation wore off and began to short on the frame of the car which caused it to stall.
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Automobile(s): CTS-V
    Feb 2003
    California
    3,987
    I have a weird issue on my V that happens sometimes. When I start it I run the key through the first two steps (acc, run) and right into the start and let go. It has happened about 3 times since I have owned it (first time freaked me out) where the key "jumped" back beyond the "run" position. This told the car to turn off and it sounded like it may have stalled. I realized this when I turned the key forward, it clicked into the correct position. Maybe you did what I did and hte key was not all the way in the "run" position..
    Let us know.
    Reed
    http://www.cadillacfaq.com
    Nov 2004
    16
    The Dealership Just Called Me And Told Me My Crank Shaft Position Sensor Was Bad....ha Ha Ha./...what In Gods Name Is That!..well Anyway My Babys Back In My Driveway.
    10secvette's Avatar
    10secvette is offline Banned
    Oct 2004
    50
    480
    could be
  8. Remove Advertisements
