CTS 3.6 engine year compatibility
Results 1 to 4 of 4
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, CTS 3.6 engine year compatibility in Cadillac Engine Discussion; My 2006 CTS with a 3.6 has jumped the cam timing chains and locked up the engine with only 84,000 ...
    tsloms is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2008
    20
    My 2006 CTS with a 3.6 has jumped the cam timing chains and locked up the engine with only 84,000 miles on it. I am in need of a complete engine to replace mine. Are there any differences in the 2004-2007 engines and are they different than the later non-DI 3.6 engines built after 2008?
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    394
    Re: CTS 3.6 engine year compatibility
    Any 3.6 cts engine from 04-07 should be a direct replacement.
    Apr 2008
    20
    Thank you,
    I tore my engine out last night to find that there was a couple quarts of coolant in the oil and #6 rod disintegrated. The internals are all junk!!!
    Apr 2008
    20
    Quote Originally Posted by ternstes View Post
    I'm having issues with trying to find a replacement 04-06 engine but have found that the 07 is the same engine as used in the 08-09 Saturn Aura, Vue, Pontiac G6, STS, CTS.
    If I am swapping over all external engine components can I get one of the later 08-09 engines and bolt it in? These can be found for less than a grand easily with low miles.
  7. Remove Advertisements
