3.2l CTS Misfire Cylinder 1 3 5
Results 1 to 4 of 4
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, 3.2l CTS Misfire Cylinder 1 3 5 in Cadillac Engine Discussion; Alright so heres the deal. Have a 2004 CTS 3.2L Manual transmission Cadillac with 58,000 miles. On a cold day ...
    cozmo1311 is offline Cadillac Owners Member
    Automobile(s): CTS
    Oct 2010
    1
    Alright so heres the deal. Have a 2004 CTS 3.2L Manual transmission Cadillac with 58,000 miles. On a cold day back in January My CTS started to flash its check engine light when idling. Great, so I hook up my OBDII reader and the codes are as follows
    P0300, P0301, P0303, P0305
    meaning Random Misfires on Cylinder 1 3 and 5
    Conclusion= bad coil pack, or foiled spark plugs
    What I did? I replaced the passenger side coil pack with a brand New AcDelco Oem coil pack for cylinders 1 3 5 and I replaced spark plugs with bosch 4 ground oem spark plugs.
    Yet, still that the car shakes at idle and flashes the check engine light. Dam right
    One more thing to add, when I was replacing spark plugs I found a few drops of oil in the spark plug cavity, and the old plugs where foiled. So I cleaned up as much oil as I could and put the new plugs in.
    So what is wrong I ask? Bad compression, bad camshaft sensor, has anyone had similar problems?
    Thanks
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    Re: 3.2l CTS Misfire Cylinder 1 3 5
    Quote Originally Posted by cozmo1311 View Post
    Thanks
    well, few things to note, it seems all your misfires are coming from the same bank. This would lead me to believe the fault isn't with the individual cylinders but perhaps something that all those cylinders have in common. In your case they are all on the same bank. So I doubt it's a individual coil, spark plug or injector issue. I would suggest you check the wiring for the injectors and coils on that side. Look for a possible poor ground or connector. I had a similar problem after a rebuild and it turned out I hadn't tightened the ground for the injector circuit properly. I suggest getting a jumper to a good ground then try closing the ground circuits individually or using an OHM meter. I'm willing to bet this may be your problem. There is also a fault code for bank 1 or 2 injector or ignition circuit fault so keep an eye out for this too.
    Marty23 is offline Cadillac Owners Member
    Automobile(s): NONE
    Jul 2012
    23
    4
    i had the same exact issue with my 2003 cts manual. My head gasket was blown and i replaced it myself to save a shit ton of money. do a compression test on all 3 cylinders and see what comes up. cylinder specs calls for 100- 130 psi
    Brooke is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac CTS 3.2 V6
    Jul 2016
    21
    1
    I see that this post is fairly old but I'm having the same issue with my 2003 CTS 3.2 V6. It all started a few months ago. My timing belt broke while driving down the road and needless to say it bent the valves on one head. I spent right at $400 for the valves, gaskets, pretty much the whole nine yards to get it fix. My dad is the one who put it all back together for me since he's worked on cars his whole life he knew what he was doing and got more advise for putting the car back in time. He just recently got it all out back together and now it's missing like you wouldn't believe. The whole car shakes. He hooked it up to a scan tool and it's saying its misfiring on cylinder 1,3,5. So he chnaged the plugs and cool pack only for it to continue doing the same thing. He's done about all he can think of to get down to the problem. So, my point of replying is in hopes you could give me some tips on what it could possibly be. To me, it's sounding like a head could be cracked because it's not running on one side of the motor and not building compression. And tips would be very useful at this point!
    Thanks!
    -Brooke
  7. Remove Advertisements
