Volant Q - How get MAFS Connector Off?
Results 1 to 9 of 9
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, Volant Q - How get MAFS Connector Off? in Cadillac Engine Discussion; OK, installing the Volant. How do I get the mass airflow connector off without busting it? Thanks!...
    c5 rv's Avatar
    c5 rv is offline Cadillac Owners Connoisseur
    Automobile(s): 91 Allante (gone), 06 SRX (gone)
    Jun 2003
    Michigan
    4,396
    odysseus's Avatar
    odysseus is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS Manual Trans., '93 STS
    May 2004
    Yorktown, VA
    54
    3,035
    Re: Volant Q - How get MAFS Connector Off?
    As I recall when I did my TonyA mods, you hold the base of the connector with your thumb and forefinger and slide it inboard (toward the center of the car, away from the fender) about a quarter of an inch. Then you can lift the connector straight up.
    c5 rv's Avatar
    Jun 2003
    Michigan
    4,396
    Nope, that technique didn't work. BTW, this is an '04 with the 3.6 engine. Here are the front and rear views of the offending plug.
    c5 rv's Avatar
    Jun 2003
    Michigan
    4,396
    The member known as ZildjianB on another forum was kind enough to outline the correct tab to pry up in yellow. After that, installation was only about and hour. BTW there were a lot of little leaves in the the old air filter - sucked out of the fender well. When I bought the car last fall, there were lots of these same little leaves all over the car and in every crevice.
    RobertCTS's Avatar
    RobertCTS is offline Cadillac Owners 10000+ Posts
    Automobile(s): Black the Darkside
    May 2004
    Central Ohio
    22,418
    Quote Originally Posted by c5 rv
    C5,
    Leaves in your filter box!? I've had mine apart several times..no leaves.
    You're mulching yard leaves with the CTS aren't you
    c5 rv's Avatar
    Jun 2003
    Michigan
    4,396
    Quote Originally Posted by RobertCTS
    C5,
    You caught me! Since I use my leaf blower to dry my cars, I have to use something for the leaves. I just attach a hose to the intake port on the airbox and vacuum up the leaves. I hollowed out the air baffle part of the airbox for added leaf capacity.
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    I knew it, I knew it! A John Deere CTS. It had to happen
    c5 rv's Avatar
    Jun 2003
    Michigan
    4,396
    Hmm, if I can find ways to attach the mower deck, snow blower, front blade, and tiller to the CTS, I could free up the room in the garage that my JD 318 consumes. I shoulda bought a green '03, eh?
    10secvette's Avatar
    10secvette is offline Banned
    Oct 2004
    50
    480
    carefull
  12. Remove Advertisements
