Results 1 to 8 of 8
Thread: Clicking noise in 3.6
    73survivor is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    5
    I am looking to buy a 2008 STS AWD with the 3.6 engine. When I started it up at the dealership there is a ticking noise coming from the engine. As the engine warms up it gets quieter but it is still there. I was told that this is the normal operation of the high pressure fuel pump and injectors. The car has only 20k miles on it. Is this ticking sound something to be concerned about? Will it get worse as more miles are put on it? Has there been problems with the fuel pumps or injectors? I want to buy a good car. Anyone have any experience with this issue? TIA
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    Re: Clicking noise in 3.6
    hard to say, Has the car always done this or is this something new, and is it getting progressively worse.
    tonyfort's Avatar
    tonyfort is offline Cadillac Owners Fanatic
    Automobile(s): Former owner 2008 CTS
    Mar 2010
    228
    If we are talking about the 3.6 Direct Injection engine then yes; the ticking is a normal sound of the direct injection system (though the DI ticking certainly does make it tough to determine if the engine itself does in fact have a different ticking noise that is actually a problem...)
  5. #4
    anfpak is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6L V6
    Dec 2010
    32
    10
    I know this is an old thread, but i didnt want to start a new one with the same question. Mine is a 2007 3.6L and is doing the same thing... the clicking noise (sounds like its coming pretty close to the windshield under the hood), which seems to go away after the car has warmed up. Did they have DI in 2007, or do I probably have a different issue?
    Thanks!
  6. #5
    Dec 2007
    5,630
    Quote Originally Posted by anfpak View Post
    Thanks!
    You should ask in the CTS section. The ticking is coming from Purge Valve Solenoid, and the faster it ticks, the more likely theres a problem. Youll hear it just behind the engine on the battery side.
  7. #6
    dboydr's Avatar
    dboydr is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS 3.6L
    Oct 2012
    Washington State
    38
    44
    The DI 3.6L 300HP engine was introduced in 2007.
  8. #7
    Sep 2007
    Wilmington, NC
    13,969
    Quote Originally Posted by dboydr View Post
    in Cadillacs it was first used in the 2nd Gen CTS (2008 Year Model... Fall 2007)
  9. #8
    93DevilleUSMC's Avatar
    93DevilleUSMC is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 SedanDeville (RIP), 2006 CTS (current)
    Dec 2006
    Georgia
    30
    3,338
    My 2006 had this problem. It turned out to be the EVAP canister/solenoid on the top right of the engine. Part was $35, and I got it installed right there in the Autozone lot. Problem solved.
  • You may not post replies
