3.6L: Stumble/lag on initial throttle tip-in
Results 1 to 6 of 6
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, 3.6L: Stumble/lag on initial throttle tip-in in Cadillac Engine Discussion; I started to notice an intermittent stumble, lag on initial accleration (throttle tip-in) in 6th gear 2 weeks ago. Now ...
    schnack is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jul 2008
    4
    I started to notice an intermittent stumble, lag on initial accleration (throttle tip-in) in 6th gear 2 weeks ago. Now it has occurred in at least one other gear, here's some maintainence history:
    2005, 3.6L 6 speed, 78k miles
    -Replaced under warranty at 49,700 miles: Timing chains, clutch and shift linkage bushings, driveshaft
    -Cadillac serviced at 71k, Fuel injector system cleaned due to 2,4,6 misfire.
    replaced by self, air filter
    Next steps i'm considering - flush diff, trans. fluid., have dealer re-check for misfire(s).
    Any suggestions?
    Spyke's Avatar
    Spyke is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac CTS 3.6L VVT
    Sep 2007
    Montreal, QC
    1,062
    Re: 3.6L: Stumble/lag on initial throttle tip-in
    have you clean the maf sensor yet?
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    are you getting any codes ?
    webbnr432 is offline Cadillac Owners Member
    Automobile(s): 2005 CTS 3.6
    Sep 2010
    30
    3
    having same problem on my 2005 3.6 with 79k aswell mine is an automatic n e suggestions on where to start to look for the problem??
    gterrell is offline Cadillac Owners Member
    Automobile(s): 2005 CTS, 3.6 LY7
    Nov 2010
    38
    I'm having a similar issue with my 2005 CTS, 3.6. I had a misfire on cylinder 2, changed all plugs and cleared codes. The engine runs great under load but stumbles intermittently at idle and has no fault codes. I can't hear any whistling or sucking noises as if the intake manifold were leaking BUT since the problem occurred after having to remove it I have to assume it's that or a vacuum line. What all should I check before taking it to a shop?
    Nov 2010
    38
    I cleaned the MAF sensor as mentioned above....problem solved.
  9. Remove Advertisements
