need 3.0 help
Results 1 to 5 of 5
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, need 3.0 help in Cadillac Engine Discussion; Hello everyone. I'm here because I'm doing research on a project. I own a 2003 Saab 9-5 with a turbo ...
    Sparky's 9-5 3t is offline Cadillac Owners Member
    Automobile(s): Saab with a turbo Catera motor
    May 2010
    need 3.0 help
    Hello everyone. I'm here because I'm doing research on a project. I own a 2003 Saab 9-5 with a turbo 3.0 Catera motor. Most on my Saab forum say the motor can't handle much more than stock boost. The motor has a G17 running off the front bank of cylinders. Basically, I'm on a quest to make her twin turbo. I TIG and fab for a living, so fabrication costs are nil. My only expenses will be parts and computer tuning. I need help being pointed in the right direction as to who would have the knowledge I need to build up my motor to handle bigger turbos. Please take this seriously
    Thank You
    May 2010
    Re: need 3.0 help
    Somebody? Please? 75 views and no responses?
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    Re: need 3.0 help
    Response. Id bet I can help as much as the people whove looked at this before me.
    If someone on this board has an answer, they will let you know. This is a very helpful board. If nooone responds, you have an answer.
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    974
    Re: need 3.0 help
    The story is the same as with every stock motor out there. If you want it to handle more boost you have to strengthen and balance the motor. This means high performance rods and pistons, and a lighter balanced crank. Less rotating mass = higher rpms.
    Long story short bring the engine to a machine shop, size the pistons and rods, then have them installed.
    Quote Originally Posted by Sparky's 9-5 3t View Post
    Thank You
    goldenb19 is offline Cadillac Owners Member
    Automobile(s): Vectra SuperTouring
    Oct 2012
    33
    Re: need 3.0 help
    Hi mate this has been tried in a few uk vauxhalls to no joy the biggest problem is cooling as the rear bank will get very hot! some tuned up NA 2.5 have been known to melt the no1 piston!!!! i only know of one thats been done in the uk and that cant be run too long :S and i belive the front valve springs are stronger so you would need to swap the backs out too
  8. Remove Advertisements
