many OBD II codes on 3.2
Results 1 to 3 of 3
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, many OBD II codes on 3.2 in Cadillac Engine Discussion; Hi, my car is giving me many code at the same times... here is the list : 0221 0507 0700 ...
    fritoss007 is offline Cadillac Owners Member
    Automobile(s): cts 2004
    Dec 2009
    35
    1
    here is the list :
    0221
    0507
    0700
    1779
    1795
    when the above codes are cleared then i got :
    2176
    finally when all codes are cleared...the car goes right for 3-5 days....
    2 times now...same result
    any ideas ?
    thanks alot
    Coke_O is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2L V6
    Jun 2009
    Houston, TX
    275
    Re: many OBD II codes on 3.2
    P0221 - APP (Throttle Position) Sensor 2 Circuit Performance
    C0221 - Right Front Wheel Speed Sensor Circuit Open
    P0507 - Idle Speed High
    P0700 - Transmission Control System Malfunction
    P1779 - Engine Torque Delivered to TCM Signal
    P1795 - CAN Bus - Throttle Body Position
    P2176 - Minimum Throttle Position Not Learned
    You should read up on some of the threads that are out there. There is a lot of talk about a crankshaft position sensor. My car spews out those sames codes when it is warm outside. During cold weather it works fine. I've replaced the throttle body with no luck. My next move is to replace the crankshaft position sensor. Good luck.
    -coke_o
    concorso is offline Cadillac Owners Master
    Dec 2007
    5,630
    You may want to post this in the CTS forum.
