3.6 CTS engine in a Catera
Results 1 to 3 of 3
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, 3.6 CTS engine in a Catera in Cadillac Engine Discussion; I have an X30XE engine with a FWD gearbox in a compact over here in the UK, does the 3.0 ...
    Shonky is offline Cadillac Owners Member
    Automobile(s): NONE
    May 2009
    37
    8
    I have an X30XE engine with a FWD gearbox in a compact over here in the UK, does the 3.0 Catera gearbox fit the 3.6 engine? I have so little room in the engine bay I'd need to keep my gearbox current and swap out the motor
    Cheers
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    Re: 3.6 CTS engine in a Catera
    well i am currently doing a engine swap from the 3.2L to a 3.6L in my 2003 CTS. after all of my research i have come to the conclusion that only the 04 CTS 3.6L is compatible with the 03 CTS 3.2L. i am not exactly sure what you are trying to do, but if i can assisit you any further, feel free to PM me or email me...
    askimbenim is offline Cadillac Owners Member
    Automobile(s): Deville 2003
    Jul 2009
    Lafayette, Indiana
    41
    14
    The catera RWD (or opel omega) has a 3.0 v6 German ecotec engine. Its at least 10 years old technology. The 3,6 is a newer gm engine. You might be needing a modern transmission as well because of CAN datalink. The engine and transmission ( also abs and esp and cluster) are communicating via CAN data link. There has been many upgrades between 98 and 2004. You will probably have issues with speed signals, not smooth switching with transmission because the torque modeling might be off, even a limp home power output from engine... Use a manual gearbox , that will be a better choice. You will need a gm/opel service tool to modify the ecm (probably).
    Good luck
