| Re: 2000 Catera Mixing Oil in Coolant I have A 1997 Catera and also have oil mixing with the water, causing a whitish brown sludge in surge tank and coolant system, I removed the oil cooler and the top side where lines connect showed no signs of leakage , however underside of cover showed the whitish brown sludge, not red like someone had mentioned,however I pressure checked the cooler and no leaks were found to the cooler itself(could the seals have failed) if so wouldnt I have seen oil to the top of cooler cover?)after some investigating I found out my son's mom had someone replace the heater bypass and I found they hooked up a vaccumn line that runs drivers side down by trans area to the plheumn ontop the intake, this hose is a vent and the heater bypass vac. line should have gone on this port( could this have caused the problem ?) I also pulled the radiator and pressure checked the trans cooler, thinking trans fluid was mixing with coolant, however no leaks found. I'm going to replace the t-stat. since it's right there, and do a cylinder leak down test(hopeing it's not a head gasket)anyone out there with similar problem and now corrected, please let me know,because I dont have a manual that shows belt timming, this is my only fear of removing the heads for inspection. |
