3.6 and oil fill up
Results 1 to 5 of 5
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, 3.6 and oil fill up in Cadillac Engine Discussion; When it comes time to put more oil the 3.6 engine do I need to leave it a half quart ...
    stillen is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2008
    80
    3.6 and oil fill up
    When it comes time to put more oil the 3.6 engine do I need to leave it a half quart low so as not to encourage oil consumption.
    Can I let it get a quart low before adding oil to it but by not filling it up all the way itsone and half quart low is this OK or do I need to add oil when it gets a quart low.
    thanx stillen
    Apr 2008
    80
    Re: 3.6 and oil fill up
    If I let it get a quart low then its a quart and a half low is this OK or do need to add a half quart every time to keep it half quart low.
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,921
    How about filling it to the fill mark and monitor. Not trying to be a smartass, just trying to keep it simple; it sounds as you're obsessing a bit.
    Apr 2008
    80
    HAH may be right but I just read if you fill it to full then you encourage oil consumption.
    have a good one
    lewisforjesus is offline Cadillac Owners Enthusiast
    Apr 2008
    Okemah, Oklahoma
    60
    656
    Hi Stillen. I'm thinking of buying a new CTS, so I decided to rent one to verify I like it's performance and handling(rented for a whole week). When I checked it out from Enterprise, I looked it over fairly well before departing. In the process I checked under the hood. All looked well. I did notice a slight ticking noise, but thought this might be inherent to this engine. Drove from OKC to Denver and noticed the ticking noise was more prominant. I knew this wasn't proper, so I checked the oil. It was exactly one quart low. I purchased a quart of the proper oil and filled it up. The ticking noise was completely gone. I'm thinking the oil level is fairly crittical. Hope this helps. Lewis
  8. Remove Advertisements
