2004 CTS 3.6L rough idle
Results 1 to 7 of 7
V6: 3.0, 3.2 LA3, 3.6 LY7, 3.6 DI LLT Discussion, 2004 CTS 3.6L rough idle in Cadillac Engine Discussion; My 2004 3.6L (1SC) has random vibration (lumps) during idle, worse during cold start. VIN# ... 40112860. Dealer CND my ...
    times1 is offline Cadillac Owners Member
    Automobile(s): 04 CTS Lux Sport
    Dec 2003
    Maryland
    33
    My 2004 3.6L (1SC) has random vibration (lumps) during idle, worse during cold start. VIN# ... 40112860. Dealer CND my first complaint at 3K miles. I test drove a new 3.6L 1SC CTS at another dealer, no lumps, no vibration at idle. Took it back in at 7K miles with same complaint. Tech acknowledged the problem and supposedly "reprogrammed PCM". Car still idles rough, randomly vibrates noticeably. What do you suggest as a next step?
    Speedingpenguin's Avatar
    Speedingpenguin is offline Cadillac Owners Fanatic
    Nov 2003
    Massachusetts
    29
    222
    Re: 2004 CTS 3.6L rough idle
    Perhapps its the IAC valve?
    JoeCaddy1 is offline Cadillac Owners Member
    Oct 2003
    46
    The 3.6L does not have an IAC valve. It controls air via the electronic throttle. There should be a service bulletin on rough idle. There was a calibration change after start of production to address this issue.
    Dec 2003
    Maryland
    33
    Dealer perfomred the calibration change (ECM update). Rough idle continues, cold or hot, doesn't matter. Already contacted Cadillac Customer Service. Any other suggestions?
    Devil_concours is offline Cadillac Owners Connoisseur
    Jan 2003
    Alexandria, VA
    34
    3,684
    i can feel the lump once in a while but not that severe enough for me to take the car back.
    Vesicant's Avatar
    Vesicant is offline Cadillac Owners Connoisseur
    Automobile(s): None :(
    Nov 2003
    Jacksonville, FL
    2,703
    Im speculating that if its a lump, maybe one of the cam shaft lobes have been flattened a lil bit.
    VVT Could be the culprit too.. there are many things involved with that system.
    What oil do you use? It only happens during idle and not when your driving? What about at a stop light... Does it go away when you "throttle" the engine to drive?
    Jan 2003
    Alexandria, VA
    34
    3,684
    Quote Originally Posted by JefferyG
    i notice it once in a while on stop light as well. Also it's more noticeable when you first start(more vibration). I'm making a list of all the things that are wrong with the car and taking it back.
    http://www.cadillacforums.com/forums...ad.php?t=13562
  10. Remove Advertisements
