Air leak in rear leveling shocks.... where to start?
Results 1 to 3 of 3
Suspension, Brakes and Tires Discussion, Air leak in rear leveling shocks.... where to start? in Item Specific Cadillac Discussion; my car has to have an air leak for the rear shocks somewhere... the compressor is ALWAYS running... it'll run ...
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    my car has to have an air leak for the rear shocks somewhere... the compressor is ALWAYS running... it'll run for like 20seconds, but goes on every 6-10minutes..... pisses me off, and I am sure not good for the compressor, and also, if the car sits for a week without being ran, it drains the battery.....
    .... Where should I start looking for a leak.... how do I find it/test it? Any help will be great. Thanks!
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Re: Air leak in rear leveling shocks.... where to start?
    Put some soapy water in a spray bottle. get under the car and spray down the connections at the shocks, compressor, tank (if applicable), and at the junctions and splices. The one (ore more) that bubble are the ones that leak.
    FTSS is offline Cadillac Owners Member
    Dec 2003
    St. Louis
    97
    Water getting trapped between the boots and the metal housing created a ton of rust resulting in pinholes in the shock housing, so be sure to check with the suspension extended. My 7 year old originals finally failed there, and also leaked earlier at the o-ring at the plastic outlet fitting at the compressor pump, and at the plastic hose that got a pinhole near the lower control arm.
