What tire pressure? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Suspension, Brakes and Tires Discussion, What tire pressure? in Item Specific Cadillac Discussion; Originally Posted by iametarq Dumb question probably but what is CCR? (besides the band) I'm not sure but I think ...
  1. #16
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: What tire pressure?
    Quote Originally Posted by iametarq
    I'm not sure but I think it stands for Computer Controlled Ride, or somthing like that.
  2. #17
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    Quote Originally Posted by Krashed989
    Yep, you got it. (that or computer command ride, never remembered the exact term)
    Later models had a similar system, SSS. Stood for two things, speed sensitive suspension, and speed sensitive steering.
  3. #18
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    Quote Originally Posted by Katshot
    The pressure printed on the tire sidewall is the manufacturers recommended MAXIMUM pressure for that tire. It is by no means the pressure that you should inflate the tires to for normal use. The OEM of the car gives a recommendation for tire pressure. It is usually located on one of the door jambs, the glove box lid, or the owner's manual. This pressure takes into account the weight of the vehicle plus occupants and is specific for the stated tire size. If you change the tires on your car, you're left to your own as for figuring out what to inflate them to. Then it's up to you to play with different inflations until you decide what's right.
    That is almost exactly what I would have said.
