Wire wheel lock nut solution:
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, Wire wheel lock nut solution: in Item Specific Cadillac Discussion; Are your '80s and early '90s wire wheel lock nuts making you look like this guy because you lost the ...
    highonchai's Avatar
    highonchai is offline Cadillac Owners Fanatic
    Automobile(s): '85 Seville Commemorative, '69 Sedan deVille, '06 CTS Sport
    Feb 2004
    Lansing, MI
    31
    424
    LightbulbWire wheel lock nut solution:
    Are your '80s and early '90s wire wheel lock nuts making you look like this guy because you lost the tool, or have the wrong one?? well heres a solution. The following is a list of tools you will need to remove the lock nuts without the GM factory tool, 1: 7/8 inch socket, 2: hammer, 3: Rachet to fit the socket, 4: rachet extender(optional) 5: screw driver. Thats it! SO heres what you do, take the socket, make sure its your 7/8" and attach your 2" extender to it (this is optional, but a good idea, it will protect your hands from whats comming next) position the socket over the wheel cover lock nut and gently, or forcefully tap it on with your hammer, then attach your ratcheting wrench and turn in a counter-clock-wise direction. you now have your lock nut off, heres the difficult part: getting the nut out of the socket. there are a few methods for this, but if you use them all in succesion it'll work, You can use a flat head screwdriver to put down in the socket hole and tap on it with your hammer, or you can use the screw driver to wedge between the end of the socket and the lip of the lock nut. for the first removal method i suggest the blunt end of a punch or some type of metal rod, the screw driver bites into the plastic nut otherwise. How have i discovered this you ask? Well GM made different lock nuts, my '89 has the green colored ones where as my '90 has red ones, the fulcrum holes are on oposite sides, therefor the green tool wont work, so i devised this method and decided to pass it along. Please use this on your own car, and not to score some caddy wire wheel covers!! OH, and suggest this to your service garage if they dont have the tool, DONT let them use vice grips! Take it easy guys.
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: Wire wheel lock nut solution:
    When I had cars that had the wire wheel covers with the locking nuts, I removed all of the special bolts and replaced them with bolts that had TORX heads. Not too many hubcap thieves carry a TORX set with them. If they try to pry your caps off and they don't come, they figure you have the locks and leave them alone. In the meantime, you or any garage can get them off without any major surgery. And a drop of neverseize on the threads doesn't hurt either.
    rltsr is offline Cadillac Owners Member
    Apr 2004
    1
    Can anyone help me find some green lock nuts? 205-788-7230 Thanks
    El Dobro's Avatar
    Sep 2003
    1,471
    Your local GM dealer is pretty much it.
    Jetsun is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac CTS
    Aug 2010
    Vancouver Island
    Above solution didn't work for me... but I did get them off without ruining the wheel cover by spraying WD40 on it the nut and then using a pair of curved pliers to turn the nut... came right off.
    ruttrow's Avatar
    ruttrow is offline Cadillac Owners Member
    Automobile(s): 78 Coupe Deville
    Jan 2012
    Central North Carolina
    52
    63
    I tried needle nose pliers. Didnt budge. I went out and bought needle nose vise grips. Nothing. Then I went out and bought a fancy drill bit that screws into a bolt, in order to move it. It would not even dent the screw head. #$%^(*&(&.
    How did the bad guys steal hub caps so quickly back in the day?
    GM dealer wants $100 to take them off. Argh. I may try the 7/8 socket trick mentioned above.
  9. Remove Advertisements
