front suspension rattle 1999 Deville
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Suspension, Brakes and Tires Discussion, front suspension rattle 1999 Deville in Item Specific Cadillac Discussion; I have a 1999 Deville with a 275 H P northstar . The car has developed a muted front end ...
    RRG
    RRG is offline Cadillac Owners Member
    Aug 2004
    61
    I have a 1999 Deville with a 275 H P northstar . The car has developed a muted front end suspension rattle at slow speed over rough roads . Has anyone else delt with this problem and if so what might it be ? I am thinking either a bushing at the top of the struts or a brake disk rattle . The struts work well and are not leaking , and I have recently replaced all brake discs and roters .
    Thanks
    RRG
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    69
    962
    Re: front suspension rattle 1999 Deville
    Tie rod links. One on each side - easy replacement. K_C
    RRG
    Aug 2004
    61
    Thanks KC
    Is this easy for a mechanic to spot when the car is up on the hoist . I had the car in the shop and they could not spot anything that would cause the rattle .
    RRG
    Aug 2005
    NY Capitol District
    69
    962
    Should not be a problem. Only linkage piece that runs vertically. End bushings go, causing the rattle. Take it to a good alignment shop, they'll sort it out.
    Search in the Suspension Forum for additional info.
    house's Avatar
    house is offline Cadillac Owners Fanatic
    Automobile(s): 2002 Cadillac Deville DHS
    Sep 2006
    SE Michigan
    212
    did the problem start right after u replaced that stuff?
    Camuchi is offline Cadillac Owners Member
    Automobile(s): 1999 Deville Concours
    Aug 2006
    LA (Lower Alabama)
    28
    Look over in the tech tips section
    "Front End Clunk Fixed Easy" worked on mine maybe you can get lucky too.
    -Matt
    Cyberdan3 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac STS
    Nov 2003
    31
    154
    I would check the sway bar links/bushings or like you said the upper strut mount.
    RRG
    Aug 2004
    61
    Thanks guys .I took the car to a good front end shop and they replaced the front stabilizer links (both sides) at 150.00 each with 65.00 for labour . The rattle is gone . Hope this helps anyone else with a similar problem .
    RRG
    Nov 2003
    31
    154
    Those stabilizer links (sway bar links) are often the cause.But it seems like you paid a lot!! $365?
    RRG
    Aug 2004
    61
    I agree , but it seems everything for a Cadillac costs more . Parts for my Toyota SUV are cheaper . Anyway that is Canadian dollars , I live in Nova Scotia .
    RRG
    Aug 2005
    NY Capitol District
    69
    962
    Quote Originally Posted by Cyberdan3 View Post
    That's what I meant to say. Yes - price a bit steep. Parts aren't that much.
    CSN
    CSN is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac DEVILLE CONCOURS 88K miles
    Jan 2007
    VIRGINIA
    9
    Quote Originally Posted by krimson_cardnal View Post
    Are you speaking of the stabilizer bar links up to the strut assembly or tie rods to the steering? I am chasing a low freq rumble in front at low speeds. Can the ride control strut itself be the problem?
    boxhalr188 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Feb 2007
    68
    My first post here but I'm sure it won't be my last, looks like some good info. My '98 ETC has the clunking noise and from the posts I'm sure it is the sway bar ends as they have a little play. (do all cadillacs do this my 93 sts did the same but I solved the problem by selling it.) What I want to know is this a home garage repair and if so what precautions do I need to take.
  16. #14
    Mark313 is offline Cadillac Owners Member
    Automobile(s): 1999 Cadillac Deville Concours
    Dec 2007
    Michigan
    27
    41
    I have this same exact problem. I have a 99' Deville Concours. After looking on rockauto for stabilizer bar links, what part do I need? ACDELCO Part # 45G0202 orACDELCO Part # 45G0052? Thanks for the help.
  17. #15
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    Quote Originally Posted by Mark313 View Post
    I did not look up pn's but look at the illustrations, then look at your car's links. I don't know why they have so many that are not right.
    I just did it on my 97 STS. I rate it a 1.5 out of 10. The ends of the links are tapered and stick in the bracket. I used a 2 jaw puller to force them out, a big hammer probably would have worked.
    Just be careful to support the car and jack up both sides evenly. Then there will not be a twist on the stabilizer link which puts tension on the links.
  18. Remove Advertisements
