Results 1 to 2 of 2
Thread: IO39 Service Ride Control
    Feb 2004
    1
    I have been reading the threads on this IO39 code. very interesting! I have the same problem on my 95 Deville I just had a new transmission put in by the Cadillac dealer. When I got the car back the IO39 code has stated to come on each time I start the car. The dealer told me I probably needed new struts on the front at a very expensive cost. I don't believe that replacing the transmission would cause me to need new struts. Does anyone out there think that the dealer may have left some wires loose somewhere under the car? If so where and how do I find the loose wire? I have looked all under the car and do not see any loose wires.
    Thanks for the help.
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    Re: IO39 Service Ride Control
    interesting , after the tranny job the i039 came up ? looks like i need to investigate the speed sensor area of things .....
  • You may not post replies
