where is the fuse for the electronic level controller
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, where is the fuse for the electronic level controller in Item Specific Cadillac Discussion; where is the fuse located for the E.L.C. on a 96 caddy deville, I looked at the owners manual but ...
    rayntx is offline Cadillac Owners Member
    Feb 2004
    13
    where is the fuse located for the E.L.C. on a 96 caddy deville, I looked at the owners manual but it is different that the fuse diagram that is on the fuse box that is on the drivers side.............need some help out there..........
    beemer2k is offline Cadillac Owners Fanatic
    Jun 2003
    253
    Re: where is the fuse for the electronic level controller
    Don't know if this will help, but... I have a 96 STS and there are two fuse boxes - one in the engine compartment, and one in the trunk behind left rear seat that you have to pull the molding (sp?) piece out to get to.
    Good luck.
