INSTALLED ANTISWAY KIT STILL THUMP/clunk
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, INSTALLED ANTISWAY KIT STILL THUMP/clunk in Item Specific Cadillac Discussion; Today had antisway link kit installed Front & Rear 94 Concour N* 4.6l FE1 Soft suspension. Car handles much "tighter" ...
    C170B is offline Cadillac Owners Fanatic
    Automobile(s): '64 Cpe Deville, '94 Concour,2012 Prius C, 2010 RAM 1500 red
    Jan 2004
    St.Louis, MO
    163
    Car handles much "tighter" now but still Clunk Thump sound from front Both sides and esp right rear...
    Nothing appears loose or worn..
    What else could it be?
    I am throwing dollars and parts at this car and problems remain.
    Regards,
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: INSTALLED ANTISWAY KIT STILL THUMP/clunk
    Towards the middle of the bar there are two bushings securing the bar to the frame. Those bushings may be worn, damaged, or even out of place.
    Caddyshack100 is offline Cadillac Owners Connoisseur
    Automobile(s): 99STS,2004 Jeep Liberty Renegade,98 Deville RIP
    Nov 2005
    1,054
    If its also in the rear, the culprit could be the rear Knuckles that the bearings sit in, they have rubber bushings top and bottom, and in order to replace those, the whole unit has to be replaced, at around 500 per side. To check, have the car hang on a hoist and with tires off, move the rear control arms up and down, that is the only way to tell if you have movement.
    EldoRedo's Avatar
    EldoRedo is offline Cadillac Owners Fanatic
    Automobile(s): 1991 ETC (Crimson)
    Jul 2006
    Bethesda, Md.
    232
    I had this exact problem and new bushings fixed it.
  7. Remove Advertisements
