Something is seriously in my suspension
Results 1 to 4 of 4
Suspension, Brakes and Tires Discussion, Something is seriously in my suspension in Item Specific Cadillac Discussion; Okay, Recently my 99 STS has started pulling to the right. Checked tire pressure and treadwear on each side and ...
    tman2093's Avatar
    tman2093 is offline Cadillac Owners Fanatic
    Automobile(s): 1999 White Diamond STS with Sirius, 2001 Silverado
    Jun 2006
    Chapel Hill, NC
    440
    Something is seriously messed up in my suspension
    Okay, Recently my 99 STS has started pulling to the right. Checked tire pressure and treadwear on each side and the pressures are even and the tread wear is off by 1/32(right side is less). It has progressively pulled harder to the right this past week. I'd say I have to hold the steering wheel at least 15degrees to the left of center to go straight.
    Also, when cornering in a parking lot, or going over speed bumps, the suspension is squeaking alot. I read on a CTS thread about the sway bar bushings perhaps being unlubed, I have no way to check this until the weekend, but what else could i be looking at?
    Edited for title content
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    Re: Something is seriously in my suspension
    Sounds like you need an alignment. Have you had it checked?
    Don't waste time or you'll be buying a new tire!
    For the squeeking, shoot the sway bar bushings with WD40 or something. If it goes away, consider replacing them. If not, shoot another joint and test drive. Repeat until you find the culprit.
    tman2093's Avatar
    Jun 2006
    Chapel Hill, NC
    440
    Since a mod removed eff-ed from my title of the thread, could you replace it to messed up or something?
    I havent had it looked at, no, im a college kid and I have little time and money to spend. I'll have to find some for the alignment.
    For the alignment, will the shop know the figures or would I be best to come armed with my own alignment values? I know Hunter makes a road force tire balancer system, do they make an alignment one to, I believe ive heard of such a thing.
    tman2093's Avatar
    Jun 2006
    Chapel Hill, NC
    440
    This past weekend i had a flat on the right side front, so i went to have it patched and we discovered that my right front wheel is corroded on the inside very very badly. Curiosity made me ask them do demount all the tires to inspect such corrosion. 2 wheels were heavily corroded on the inside, 2 were perfect. Left the car there and went to another town to buy 2 new wheels and i broke down and got 4 new michelins since i was needing tires anyway.
    So now it drives straight, apparently my tire pressures got screwed up when i tested the car for pulling to the right, so thats fixed, i'll work on the squeak the next time i go home
  7. Remove Advertisements
