RearBrakes 96DeVille
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, RearBrakes 96DeVille in Item Specific Cadillac Discussion; Getting set to do brakes all around. Pads and rotors are here and Monday's set aside. Question is what do ...
    krimson_cardnal's Avatar
    krimson_cardnal is offline Cadillac Owners Enthusiast
    Automobile(s): 96DeVille
    Aug 2005
    NY Capitol District
    69
    962
    Question is what do I need to be able to turn/screw/twist in the rear caliper pistons? Might I have something in the shop that would work or do I need to buy something??? Fronts take a c-clamp but not the rears.
    Thanks K_C
    Aug 2005
    NY Capitol District
    69
    962
    Re: RearBrakes 96DeVille
    FYI - this is what's needed:
    Along with an 18mm spanner and a box of bandaids - gotta pull the caliper mount to get the rotor off. Caliper will easily swing-up to get the pads, but the whole deal needs to be removeed to get the rotor off. DO NOT seperate caliper from bracket OR pull brake line.
    KC
