Deville 95 rides high, is this a ELC problem??
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, Deville 95 rides high, is this a ELC problem?? in Item Specific Cadillac Discussion; Sometimes it is just a bit high, but often it is at what seems to be a the max height ...
    mac_waterville is offline Cadillac Owners Member
    Automobile(s): Cadillac 95 Deville
    Sep 2006
    MN
    3
    Sometimes it is just a bit high, but often it is at what seems to be a the max height the air shocks can take it. I first noticed this after getting new tires. Could they have messed up something.... like a wheel position sensor??
    1995 Deville has 81,000 miles.
    Surprisinly I don't show any codes as being bad, so the auto leveling control must think everything is OK.
    The air compressor runs sometimes when the vehicle is started. Many times I don't hear the compressor run as the back end is already as high as it can go. I believe I used to hear it run everytime I started the car.
    The ride is not good when it is all jacked up to the max. Other than putting 300 lbs in the trunk what can I do or what can I look for?
    Thanks!
    MAC
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: Deville 95 rides high, is this a ELC problem??
    Try disconnecting the airlines from the shock to relieve the pressure. I think you have a problem with your exhaust valve. The exhaust valve works like a relay. It has an electromagnetic coil that actuates the valve. If the valve is stuck then it won't release the pressure.
    Also to the forums!
    Sep 2006
    MN
    3
    SmileRe: Deville 95 rides high, is this a ELC problem??
    Thanks for the reply Krashed.
    I've been assigned major yardwork tasks by the DW so didn't get too much done yesterday. Did manage to find the ELC fuse in the trunk and pulled it out. No change overnight... so guess I don't have a leak
    I have no idea where the exhasut valve is, or what it looks like. I just ordered a set of OEM service manuals as I have a only moderate amount of mechanical skills and don't like flying blind.
    MAC
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    The exhaust valve is inside of the compressor assembly... I've never taken it apart before so I'm not sure of what to look out for there.
    Sep 2006
    MN
    3
    Thanks Krashed... looks like you were right on on the initial call.
    Just to give an update.
    Received the OEM manuals, they did help a bit.
    Letting the air out did lower the car, when it bottoms out measures about 21.5" from the rear wheel fender wheel to the road. When it is pumped up high it measures 24.5".
    I disconected the height adjustment linkage. When moved up the compressor runs. When lowered it shuts off.
    So far so good. However when taken below the shut-off point... nothing happens. So it does look like the exhaust valve is stuck.
    It looks like the exhast value isn't working. The manual indicates that the valve is part of the compressor assembly and doesn't show any detail.
    Don't know what to do for sure. Don't really feel like buying a compressor. I just put the car at about 22" from the point I was measuring as that seems to be about "right" to me. I then pulled the fuse. I've had it this way for a week and can't measure any change in the height so far.
    MAC
    Leeb's Avatar
    Leeb is offline Cadillac Owners Enthusiast
    Automobile(s): did this once... 86 Deville, 86 300E, 78 R100rs
    Jun 2005
    Palm Spgs CA
    57
    517
    Quote Originally Posted by mac_waterville View Post
    MAC
    Other than placement they haven't made many changes to the compressor in umpteen years... visit a salvage yard and look for some 'pretty' ones... you'll most likely find one that can work for you.
    If not, you'll certainly be able to swap out the exhaust valve... assuming you're the 'curious and destructive' type...
  9. Remove Advertisements
