Front Hub Seals
Results 1 to 2 of 2
Suspension, Brakes and Tires Discussion, Front Hub Seals in Item Specific Cadillac Discussion; Thanks to you folks - I've been sucessful in replacing the front struts and brakes on my 97 STS. But ...
    rdmsyr is offline Cadillac Owners Member
    Automobile(s): 1997 Seville STS
    Jul 2006
    CNY
    5
    QuestionFront Hub Seals
    Thanks to you folks - I've been sucessful in replacing the front struts and brakes on my 97 STS. But like many of you, I have the death code for the front left wheel sensor (C1232). I checked continuity and found that the sensor was open, so, decided to replace the hub assembly with a BCA unit. Which has been sucessful so far except - there is no seal provided with the new and wondering if anyone knows if one is available.
    Thanks!!!
    El Dobro's Avatar
    El Dobro is offline Cadillac Owners Connoisseur
    Sep 2003
    1,471
    Re: Front Hub Seals
    What seal?
