Idler Arm and Tie Rod Problems.
Results 1 to 8 of 8
Suspension, Brakes and Tires Discussion, Idler Arm and Tie Rod Problems. in Item Specific Cadillac Discussion; On my 81 Seville, the Idler Arm, both Tie Rods, and the outer cv boots are shot. How hard should ...
    devilleconcours100's Avatar
    devilleconcours100 is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Cadillac Deville Concours, 1981 Cadillac Seville
    Sep 2004
    196
    On my 81 Seville, the Idler Arm, both Tie Rods, and the outer cv boots are shot. How hard should all of this be to replace. Should I get new CV shafts rather than repairing the old ones. Also my brake light is on, and the parking brake is up. What else could it be?
    Thanks for your help,
    Dave.
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,930
    Re: Idler Arm and Tie Rod Problems.
    The axle assemble is always cheaper to buy than a CV joint and it takes the same amount of work.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
    RedGalant2k1's Avatar
    RedGalant2k1 is offline Cadillac Owners Connoisseur
    Automobile(s): N/A
    Apr 2006
    Michigan
    1,108
    The idler arm and axle shafts won't be a piece of cake unless you know what your doing.
    I also agree its much easier, and in many cases nowadays cheaper to replace the entire cv chaft than just try to reboot an old cv shaft.
    Leeb's Avatar
    Leeb is offline Cadillac Owners Enthusiast
    Automobile(s): did this once... 86 Deville, 86 300E, 78 R100rs
    Jun 2005
    Palm Spgs CA
    57
    517
    But the CV is LOTS more fun... and greasier!
    Automobile(s): N/A
    Apr 2006
    Michigan
    1,108
    Quote Originally Posted by Leeb View Post
    Not anymore. Its as simple as unbolting the old axle a installing the new axle. You don't have to grease anything anymore.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    Brake lite on could be as simple as low fluid in master cyl.
    Sep 2004
    196
    The brake reservoir is full, and the parking brake has released. I have been really busy this week, but I will try and keep you updated.
    Thanks, Dave.
    Leeb's Avatar
    Jun 2005
    Palm Spgs CA
    57
    517
    Quote Originally Posted by RedGalant2k1 View Post
    I meant removing JUST the CV and replacing it.
    Great time to be had by all!
  11. Remove Advertisements
