Air compressor for the Load Level/ Air ride suspension
Results 1 to 7 of 7
Suspension, Brakes and Tires Discussion, Air compressor for the Load Level/ Air ride suspension in Item Specific Cadillac Discussion; I Need some help, I must confess that I am not a Cadallac owner, but I needed a small tiny ...
    twisted_ed is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2006
    I Need some help, I must confess that I am not a Cadallac owner, but I needed a small tiny air compressor to operate a small air ram and I went to the junk yard and ended up getting a small compressor that came out of a cadilac. The junkyard was a little useless at providing any info on the model, year etc of the pump. They think mabe an "88 caddy" as they put it.
    There is a black ground wire, green wire that turns the pump on and a white and orange wire that comes out of the top. I do not know what the white and orange wire are for and was hoping that someone might know what they are for.
    If it helps this was stamped on the housing:
    Delco Products
    Dayton Ohio USA
    5044865
    23281
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: Air compressor for the Load Level/ Air ride suspension
    Probably the exhaust valve.
    Aug 2006
    How does the exhuast valve work?
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    It's basically a soleniod valve that releases the pressure in the lines.
    Feb 2003
    california
    69
    6,640
    White orange wire is for power, black for ground. Green is test lead, not connected at all normally. The pump is activated by a level sensor which supplies power to the orange/white wire. In the car, to verify the pump is good we would hook a jumper wire from the battery postive post to the green wire which should activate the pump regardless of level sensor position. I would use either wire as power.
    richie_v is offline Cadillac Owners Member
    Sep 2006
    3
    Quote Originally Posted by carnut View Post
    Can you tell me where the compressor is located in a '93 seville sts? Any help greatly appreciated! Rich. Thanks.
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Quote Originally Posted by richie_v View Post
    On top of the rear crossmember on the passenger side.
  10. Remove Advertisements
