Attention: owners needing to replace electronic struts/air shocks
Results 1 to 10 of 10
Suspension, Brakes and Tires Discussion, Attention: owners needing to replace electronic struts/air shocks in Item Specific Cadillac Discussion; I need new struts and shocks for my 92 Eldorado so I went to Oreilly's and they sell electronic struts ...
    barth875oh is offline Cadillac Owners Member
    May 2003
    Muscatine, IA
    34
    35
    I need new struts and shocks for my 92 Eldorado so I went to Oreilly's and they sell electronic struts for $61 and the electronic air shocks for $88. These are Monroe brand and would be a better solution than installing passive ones. Just an FYI.
    DjPiZdEtZ is offline Cadillac Owners Member
    Aug 2003
    23
    Re: Attention: owners needing to replace electronic struts/air shocks
    I have a 93 eldorado and 1 of my front struts is shot. How would i get in touch with this oreillys and do these replacements work as well as the originals?
    rayntx is offline Cadillac Owners Member
    Feb 2004
    13
    Quote Originally Posted by barth875oh
    hey thanks for the info, im in the process of changing my shocks on my 96 deville and went to the dealer and they said they would be over 1400 buck to get them, I need some help..............what is oreillys web address or email to see if he can help me out...............thanks.....rayntx
    May 2003
    Muscatine, IA
    34
    35
    Their website is www.oreillyauto.com . It's pretty easy to navigate.
    Feb 2004
    13
    thanks for the address, I will check it this p.m and see if I can get the shocks cheaper than the dealer................................
    Feb 2004
    13
    Quote Originally Posted by rayntx
    hey is there a tel. number that i can get, cause there are no o'reilly stores here in texas
    Big Jim is offline Cadillac Owners Member
    Dec 2003
    West of Denver, CO
    44
    When I looked at the web site, it looked like they had stores all over Texas. Just pick one and it will give you the address and phone number.
    Bob Schlossmann is offline Cadillac Owners Member
    Mar 2004
    Did you ever get in touch with O'Reilly's auto parts regarding the replacement struts for your 93 Eldorado. I just tried there web site and no struts were shown. If you did get them would you please supply the part #'s
    I have seen other years (92 sevile) using ACDELCO part # 580-2 (pair) for $168.42 from rockauto.com & monroe part#71854 for 134.65 delivered. The post I stumbled across didn't indicate if the Monroe's were for the LH or RH side.
    Lastly Gabriel also make a set. I think part # G56717. Don't know if this works. These passive struts would also require the digi-key 12 ohm 50 watt power resistor to fool the confuser (i.e. computer)
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    I have already bought the Arnott system and am well satisfied with them. But, I'm willing to learn.
    Please note my questions are in regards to the RSS and SSS controlled Seville STS models.
    I looked for shocks and struts for mt 93' STS and still find that Monroe and Gabriel do not make them.
    Monroe search for 93' Seville electrical controlled suspension
    http://www.monroe.com/catalog_lookup...R=1993&LST=477
    Gabriel no listing either.
    Are you really getting an electrically controlled shock or strut for under $850 (GM's price) each?
    I don't think so. That is why after quite a bit of research I went with the Arnott replacements.
    Are the replacement shocks noted just regular good shocks that bolt in?
    How do they deal with the error code generating that will happen without some sort of method to fool the PCM?
    -George
    Budabear's Avatar
    Budabear is offline Cadillac Owners Fanatic
    Automobile(s): 2009 3.6 DI AWD Performance Package, 2003 Seville STS
    Dec 2003
    Yonkers, NY
    128
    Oreilly's doesn't seem to sell online. You have to be near one of their stores. When you look up parts all it does it take you to a map.
  13. Remove Advertisements
