Brakes... HELP PLEASE
Results 1 to 6 of 6
Suspension, Brakes and Tires Discussion, Brakes... HELP PLEASE in Item Specific Cadillac Discussion; OK, im having a weird problem, (well at least to me its weird) I have a 2001 DTS, WHat would ...
    01devilledts's Avatar
    01devilledts is offline Cadillac Owners Fanatic
    Automobile(s): 68 SDV,04 XLR,97&99 4dr tahoe,67 lincoln,98 jeep xj, 69c10
    Dec 2004
    Glendale, Arizona
    34
    392
    ExclamationBrakes... HELP PLEASE
    OK, im having a weird problem, (well at least to me its weird) I have a 2001 DTS, WHat would cause the inside pad of the breaks to wear 1/4" farther than the outside?
    Both were changed at the same time and still over 1/4" on the outside pad. the inside pad is now gone an taken a little bit of rotor with it.
    Im puzzled by what could cause this if the pads are only being applied pressure evenly? Please help, No wheel on car as of 10 O'Clock. No one's Open
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: Brakes... HELP PLEASE
    Your slide pins probably need to be greased... Change your pads and rotors too while you're at it.
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    As stated above, most likely your slide pins, or a stuck piston. When doing a brake job, it is imperative to use brake grease, on the slide pins, and the pads themselves. If you, or a mechanic, does not use the grease, the brake parts will begin to bind, causing the pads to not self retract after releasing the brake pedal. Other than that it could be a seizing caliper piston, but I do not expect that this is your problem.
    Don
    Dec 2004
    Glendale, Arizona
    34
    392
    thanks for the reply's. All the side pins are greased and the caliper piston moved freely. I have done brake's many a times before. but thist time maybe something just got binded up, I replaced, rotors and pads on both sides, hopefully, that solves my problem.
    They should put awarning tab on both sides of the pad, (inside and out) because there was no warning that the inside pad was gone untill it was too late.
    Also, how big of a job is it to overhaul the caliper piston and change the sals in it? if its a somewhat easy task, ill probably do that just to be safe.
    thank you
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    50
    2,817
    The best thing to do after installing the pads, greased of course, is to manually slide the caliper on it's pins. This will give you the assurance that it will not bind, plus it will help distribute the gease a little better. As far as the caliper goes, I have never rebuilt one myself. But from what I understand, it is very easy. The piston will just slide out, and you replace the seal, and slide the piston back in. If this is wrong, please someone chime in. That is what I have read though. Your DTS should have brake pad wear sensors, no? These get fixed to the inside pad, as the inside pad will always wear a little faster than the outside one. Not as fast as yours just did though. This is your warning that the pads are worn.
    Don
    Dec 2004
    Glendale, Arizona
    34
    392
    This is puzzeling, I do not have wear sensors, on the pads, I don't think they come with them for my model. But who knows, I'm just gonna get the rebuild kit and do it anyway, It can't hurt to be able to stop better.
  9. Remove Advertisements
