Master cyl install
Results 1 to 14 of 14
Suspension, Brakes and Tires Discussion, Master cyl install in Item Specific Cadillac Discussion; ok how to do it and what to look for?...
    1969cadillaceldorado's Avatar
    1969cadillaceldorado is offline Cadillac Owners Fanatic
    Mar 2006
    26
    111
    Master cyl install
    terrible one's Avatar
    terrible one is offline Banned
    Automobile(s): 1976 Eldorado project
    May 2005
    El Dorado, Arkansas
    26
    1,631
    Re: Master cyl install
    You disconnect all lines to and from, then unbolt it from the booster. Then you install the new one and hook the lines back up. Then you go buy some brake fluid and bleed all 4 brakes, then fill it up and you are done.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Be sure to bench bleed the master cylinder first! Or it'll be a real pain to get all the air out later!
    Mar 2006
    26
    111
    ok well i didnt didnt bench bleed it yea i wish i would of now and i couldnt bleed the back brakes well it stops pretty good so idk if i need to but how do u bleed the back brakes
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    You might have to keep bleeding them until you get all the air out of them. The rear lines are much longer than the fronts, so it will take a lot more fluid to flush all the air out.
    Mar 2006
    26
    111
    how do i bleed the back brakes i cant find anywhere to bleed them
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    One the back side of the drum backing plate, you will see the bleeder screw. It's usually near where the brake line goes through it.
    Mar 2006
    26
    111
    Quote Originally Posted by caddydaddy
    well in the middle of the axle all the rear lines meet up thats where i bled it is that bad that i did or what?
    caddydaddy's Avatar
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Yeah, that's not the place to bleed the line, you'll still have air from that junction to the brake cylinders. Do you have a service manual for your car? Because I'm not too familiar with the '69 Eldo to tell you exactly where the bleeder screw is. It should be on the back side of where the brake drum is. It does have drum brakes in the rear, right?
    Mar 2006
    26
    111
    no i dont have a service manual but where i did bleed it,it worked cause took a while to get the air out but i just need to ask is it safe to drive car if there is still air in the brake system??
    JTraik is offline Cadillac Owners Enthusiast
    Automobile(s): Too many...
    Mar 2004
    849
    No offense... but if you cant even find the bleeder screws im very curious on how your going about "bleeding" the brakes.
    '69 Eldo's did not have rear discs yet so you are going to be bleeding a wheel cylinder. There is a junction back there which you bled (somehow ) follow the lines that split off to each wheel. Right above the line where it screws into (ON THE WHEEL CYLINDER) is a bleeder screw...
    May 2005
    El Dorado, Arkansas
    26
    1,631
    And remember, bleed until fluid is coming out of all 4 lines.
    Junkman's Avatar
    Junkman is offline Cadillac Owners Fanatic
    Automobile(s): '78 Superior Cadillac Amublance, '69 Miller Meteor Ambulance
    Dec 2004
    Northeast CT
    245
    The other thing to make sure of when you replace a master cylinder is that the push rod is properly adjusted to the new cylinder. You need the factory shop manual to make this adjustment. In 90% of the times that you are working on the car, the factory service manual will be a great help in saving you time and removes the risk factor of doing more damage than repairs... I have seen many good parts ruined or replaced because of lack of knowledge in determining if the part is good or bad. The service manual will take a lot of that risk out of the equation. It might be the best $25 you will ever spend on that car.... Junk..
  16. #14
    Mar 2006
    26
    111
    ok where i bled the brakes was the rite place the brakes place said it was so anyways CAR IS BEING SOLD i have put $600 into this car and i get everything to work and now i something is burning inside the car dont know what it is and i dont fill like dropping anymore money on this car but if someone can help me out with my new problem that would be great but if not ill sale it
  17. Remove Advertisements
