Brake broke today
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, Brake broke today in Item Specific Cadillac Discussion; Today, my brake line broke. I was coming to complete stop and as I pressed the pedal for the final-a-bit-more ...
    100
    100 is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Sedan De Ville (4.9 L)
    Oct 2003
    Woodridge, Illinois
    581
    Brake broke today
    Today, my brake line broke. I was coming to complete stop and as I pressed the pedal for the final-a-bit-more deeper pressing, it started loosing the pressure and the pedal wanted to go all the way... I am glad I didn't hit anything...
    Now I have to fix it. The lines under the driver seat going to rear brakes are rusty. To replace them, I have to disconnect the line at the ABS unit. Did GM use "bubble" flair or "double" flair for 95 SDVs? The FSM said it was ISO flair. It sounds to me the same as European, but I am not sure. What were sold at auto shops around were "bubble" (=European) and "double" (=American) and Metric. I am quite confused... When I said ISO to them, they are like ??? So, I need someone who knows better than them.
    Also, the nuts holding the line at the ABS unit are very tight. I put WD-40 on them and I will see tomorrow, but the bottom line is that I cannot afford to break them. Does anybody have any good ideas on how to remove them? They are standard 13 mm nuts, but since there is a line going at its center, a box wrench will not be an option. With an open wrench, I feel that it would strip the nut, because they are so tight...
    Thanks in advance!
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    Re: Brake broke today
    Broke? Interesting.
    If you are using new line, you will have to use whatever style flare joints your adapters and connectors require.
    Tommy Deville's Avatar
    Tommy Deville is offline Cadillac Owners Enthusiast
    Automobile(s): None
    Jan 2006
    Staten Island NY
    588
    There ar far too many stories on this forum about Caddy brake lines failing, Its somthing that should not happen, there needs to b a recall for all these models
    100
    Oct 2003
    Woodridge, Illinois
    581
    Wrong spell, huh? Flair -> flare.
    Anyway, I figured out that I need bubble, british, or ISO flare. Not double, American, or standard flare.
    Also, I was able to remove the lines at ABS unit using a 1/2 wrench. I have several 1/2 open wrenches and a couple of them fit on due to slight variation in tolerance, I suppose. They fit real tight on the nuts and I was able to turn without stripping. With a 13 mm wrench, I don't think I was able to.
    Interesting point to note is that each line has 2 different back-up nuts! One end is always smaller and another end has larger nut...
    I am still working on...
    100
    Oct 2003
    Woodridge, Illinois
    581
    Update:
    I am now done. As a temporary fix, I put compression fittings to connect both rear break lines. For now, I don't see any leak from them. I do know it is not a recommended method though. I will see how good they are.
  8. Remove Advertisements
