Metal Brake Line Flaring Issue: NEED HELP!
Results 1 to 13 of 13
Suspension, Brakes and Tires Discussion, Metal Brake Line Flaring Issue: NEED HELP! in Item Specific Cadillac Discussion; I have a 1994 STS that has had LOADS of good work done on it. A new engine has been ...
    chevyorange's Avatar
    chevyorange is offline Cadillac Owners Fanatic
    Oct 2004
    Federal Way
    44
    351
    AngryMetal Brake Line Flaring Issue: NEED HELP!
    I have a 1994 STS that has had LOADS of good work done on it. A new engine has been put in, which led to finding out that a fender bender in the past life of this car on the driver's side front wrecked the ABS unit. (Or the mechanic knocked it and won't take credit for it).
    My problem is first, a month long search of finding fittings because when pulling out the old lines, most were stripped necessitating the replacment of the metal lines on the whole left side of the car.
    NEARLY DONE, the mechanic cannot get the last part of the line to flare so it seats correctly to the brake (the metal line flare that the nut bolts over).
    Can anyone tell me why he may be having trouble with this? Is anyone in Seattle that can help me (I'm disabled but can move around and walk for short periods) with any shops in Seattle or South End that do this brake line flaring?
    Any and all input welcomed, I need my car back by the end of the week and this one end of the line is the only thing holding it up.
    Adam
    Oct 2004
    Federal Way
    44
    351
    UnhappyRe: Metal Brake Line Flaring Issue: NEED HELP!
    I guess nobody has had this combo of a lazy mechanic and a franked up brake line that won't bolt up. Apparently he had a hard time finding even the fittings that go over the brake line before the flare. Took 3 months to track one down... still on hold waiting for the flare. I have a hot date on Friday and want my STS back!!
    Thanks for letting me rant.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Double flares are VERY hard to do. It took me a long time to get it right on one of the first few tries. The flaring tool has to be attached to the line about 1/4 of an inch from the end. Then the clamp part of the tool has to perfectly centered on the end of the line otherwise the line will bend crooked. You use the concaved fitting first (its concaved with a pin in the middle so the hole doesn't close). Clamp it to the point where you get a good 'bubble' in the line. Then after that you have to use the regular flare fitting to fold the tip inside while spreading the end open.
    Oct 2004
    Federal Way
    44
    351
    Dear God. Thank you for the first answer that's made sense.
    So, this guy could be telling me the truth tha he has gone to the same shop two or three times and they've managed to screw it up.
    I found another shop that said it was "easy" so I directed my mechanic there - I assume this guy has been in the business awhile if he'd describe it as easy.
    Thanks again.
    100
    100 is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Sedan De Ville (4.9 L)
    Oct 2003
    Woodridge, Illinois
    581
    I thought Cadillac uses (at least mine, 95 SDV) "bubble" flare, not double flare. Double flare will not seal at the ABS unit and proportional valves, I think.
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Quote Originally Posted by 100
    Are you sure about that?... It says double flare in my FSM... But then again I don't have a 95 SDV.
    100
    Oct 2003
    Woodridge, Illinois
    581
    Quote Originally Posted by Krashed989
    Now, I am working on my brake lines. IF they are double flare, I will be dead. Well, my FSM says they are ISO style flare and I think that is the proper name for the bubble flare, but when I say ISO style, everybody says "huh?".
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    ISO means metric... and usually with metric you use bubble flares... But my eldo uses ISO double flares... ISO double flares are rarely ever used which is why it's so hard to find the tool... There's a picture in the FSM... I found this pic of one too...
    The surefire way for you to tell is to look at what the line connects into. Bubble flares go into concaved fittings and double flares go into convex fittings...
    bubble=male
    double=female
    100
    Oct 2003
    Woodridge, Illinois
    581
    Yes, I am very sure that mine is at least different from either of them. And I am certain that what I need is bubble flare. My FSM says just "ISO" style, but from the figure in the FSM, I guessed that it is the same as bubble flare. I even didn't know there is ISO double flare. Isn't it confusing?
    94CaddyConcours's Avatar
    94CaddyConcours is offline Cadillac Owners Fanatic
    Automobile(s): 1994 CADILLAC DEVILLE CONCOURS, 350ZR
    Jul 2004
    LONG BEACH KALIFORNIA, HOUSTON
    443
    Not if you have the pneumatic tool.
    Remeber the flare should be 45 degree for Auto not 37 like aviation.
    Oct 2004
    Federal Way
    44
    351
    Well, it appears that the problem is we have been sourced the wrong fitting. I am going to put a new post up, I need two fittings that go in at the ABS block. Mine are corroded and stripped when pulled out and no need new ones.
    The line appears to be flared fine, yet when it is put in, it leaks without even having to put pressure on the pedal.
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    You can get adapter fittings at napa... I think they are called clutch adapters, but i could be wrong.
    Oct 2004
    Federal Way
    44
    351
    QuestionRe: Metal Brake Line Flaring Issue: NEED HELP!
    I will give it a shot. It is an oddball size (small!) but I will try NAPA. I'm not sure if this is going to be a solution.
    Thanks for the idea.
    Adam
  16. Remove Advertisements
