20's on STS......minimal turn radius...
Results 1 to 9 of 9
Suspension, Brakes and Tires Discussion, 20's on STS......minimal turn radius... in Item Specific Cadillac Discussion; get a bout 60 % original turning without rubbing.... im jsut gonna go in with air tool and beat in ...
    SwitzerCadillac's Avatar
    SwitzerCadillac is offline Cadillac Owners Member
    Jan 2004
    17
    im jsut gonna go in with air tool and beat in teh seams inside the wheel wells under the plastic...this shouldnt cause any damge to anything would it...is there any electrical i should be watching for...?
    anybody had to do anything like this..? any tips.. horror stories..?
    STS_spinnin is offline Cadillac Owners Member
    Jun 2003
    34
    85
    Re: 20's on STS......minimal turn radius...
    mine is back on stocks right now and i havent notcied any difference except for the ride
    Jan 2004
    17
    maybe your wheel wells are a little bigger, than mine, maybe you have a smaller tire than i do...ive go the hankook sport k 104 245/40zr20 nice tires still.....
    i plan on doin the eibach thing and reducing clearance another inch or so....which aint gonna make things easier i know.....also, where am i gonna get this the cheapest (the eibach kit) ?
    Closet Boy's Avatar
    Closet Boy is offline Cadillac Owners Fanatic
    Automobile(s): 2004 SLS
    Jun 2005
    University Heights, Ohio
    254
    I'm running 245/35/20s on 20x7.5 rims with a 40 offset. No rubbing issues up front. Recently installed FE1 struts and Intrax springs (2 inch drop). Off the hook!
    Doing the rear springs at the moment. The STS right rear is all apart in the garage as I post. Man, what a PITA! Had to disconnect the sway bar from the frame, rear stabilizer link, upper hub/wheel bracket, and more! Your standard issue spring compressor is very hard to work with due to it's size! The rear coil is smaller than what I have replaced on other cars.
    Closet Boy's Avatar
    Jun 2005
    254
    UPDATE: Finished rear coil install. A real PITA. The 20's do not rub in tha back, and I am down 2 in. with the new coils. BTW, my rear shocks are shot.
    My next project are the rear shocks. Any suggestions on replacements? Arnott, Boston, or Strutmasters?
    Closet Boy's Avatar
    Jun 2005
    254
    Took it with my RAZR. Will take pics with proper dij camera later. On dubs...
    Closet Boy's Avatar
    Jun 2005
    254
    Sumitomo 24/35/20s from http://www.tirerack.com . Limited 20x7.5 w/40 offset from JJ at http://www.rvmwheelz.com . The wheels(blank when new) were custom drilled 5x115. Intrax springs from http://www.summitracing.com Pics!
    jcdsog is offline Cadillac Owners Member
    Oct 2003
    sc
    40
    24
    looks good!
    Closet Boy's Avatar
    Jun 2005
    254
    Following up on post. The springs have settled, and it is slight lower. Still, no issues of rubbing. Had to take the dubs off the other day ;-( Winter is here!
  12. Remove Advertisements
