'06 STS Brake Squeal
Results 1 to 5 of 5
Suspension, Brakes and Tires Discussion, '06 STS Brake Squeal in Item Specific Cadillac Discussion; I have 2,700 miles on my "high Performance" brake pads (part of the PHP). Since day one (seven weeks ago) ...
    Curious George's Avatar
    Curious George is offline Cadillac Owners Fanatic
    Automobile(s): '06 Northstar STS 1SG, PHP, ACC/HUD '06 Redline CTS-V, FG2
    Mar 2006
    Belmont, CA (halfway between S
    242
    I have 2,700 miles on my "high Performance" brake pads (part of the PHP). Since day one (seven weeks ago) my brakes have squealed softly at very low (walking) speeds at very low pedal pressures, typically during the last few feet of coming to rest at a STOP sign. I and others have posted similar complaints on the STS forum. I just found this brakes forum and am posting the matter here, as well.
    My dealer (Stewart Cadillac in Colma, CA) told me that there's a TSB on brake squeal advising that I get used to it. Anyone have any comments or suggestions?
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    50
    2,817
    Re: '06 STS Brake Squeal
    Due to the compund needed for a "high performance" brake pad, some squeal is to be expected. I would think that the squeal should be minimal though. If it is excessive, I would make the dealer warranty them. If they refuse, I would put a new aftermarket set in.
    Don
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    I have EBC Greenstuff pads on my 2000 STS, and they do the same thing, a light squeal at low speeds, low pedal pressure. It's just how performance pads are!
  5. #4
    Supercrew632 is offline Cadillac Owners Member
    Automobile(s): CERTIFIED CADDY TECH
    Feb 2005
    MI
    71
    If you read your owners manual, it states some brake squeel is normal and does not mean something is wrong with your brakes. That is almost word for word.
    Supercrew632
  6. #5
    ChicagoCTS32's Avatar
    ChicagoCTS32 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 1SC Diamond White CTS
    Feb 2006
    Lat: 41.77983, Lon: -88.07956
    34
    3,281
    You might try "bedding" your brakes. Basically, brake hard from 60 down to 10 mph. Drive for 2 minutes, repeat. Drive for 10 minutes, repeat, Drive for 2 minutes, repeat. Drive for 10 minutes with no brakes. Done. Check out baer or powerslot or some other aftermarket brake companies for the proper procedure. Brakes "glaze" over under normal driving conditions. Basically, the brake pad material wears off as dust and forms a thin sheet of glass on your rotor. That's what squeals. Bed them and you'll get rid of the squeal. It doesn't last forever, but it helps temporarily. Mine do the same thing... CTS with Sport Lux package with the high performance brakes. PITA
  7. Remove Advertisements
