Michelin Tires..
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Suspension, Brakes and Tires Discussion, Michelin Tires.. in Item Specific Cadillac Discussion; I sure am a little mad now that I've been thinking this over for a few days I have a ...
    FredMaxwell Guest
    Michelin Tires..
    I have a set of Michelins on my 1979.. they cost me well over $500
    Well they have 15,000 miles on them, or around that and they look like they've about had it. They are a few years old but still the 15,000 mile tires ought not to look like these do.
    The only thing I can figure is that alot of fast highway driving did this to them BUT I did nearly all of it through the cool night time hours.
    PS: I don't peel out often in the '79 when I drive it so that isn't what happened to these things.
    Anyone here who does alot of fast (over 100mph) highway driving you might say a word or two about how well your tires hold up.
    Now I could understand this if they were on one of my old Sevilles because I always peeled out all over hell with those and accepted the fact that I needed tires often.. or even if I'd done my high speed driving on hot pavement
    but this deal on these Michelins is really burning my ass
    I'm angry and mad about it!
    Zorb750 is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Eldorado, 2003 Audi RS6
    Apr 2005
    Oakland County, MI
    33
    1,320
    Re: Michelin Tires..
    Speed shouldn't have much effect on tire wear rates. Wheel allignment would be the biggest thing to think about. That and rotation. Front drive cars wear out front tires really quickly, even if you don't let them spin at all. Rear drive cars are actually pretty even in tire wear. Are all of your tires this worn?
    FredMaxwell Guest
    Quote Originally Posted by Zorb750
    That makes sense.. it's pretty well aligned as it stays straight if you let go of the wheel or get on the brakes
    And they rotate them free where I bought them..
    Also the car is RWD
    Apr 2005
    Oakland County, MI
    33
    1,320
    Yes I know it's rear wheel drive. I mentioned both front and rear, just for information's sake. Your car is essentially the same as the Fleetwood of the time. The wheels can be out of alignment even if it drives straight. Have it checked. Belle Tire will do it for nothing, get the printout for it before you let them do anything.
    FredMaxwell Guest
    I better have that looked at then
    Riddle me this.. if it were out of alignment wouldn't the wear patterns be uneven?
    Apr 2005
    Oakland County, MI
    33
    1,320
    Maybe maybe not. I had a case of camber misaligmnent in the rear a while back and the odd wear wasn't noticable at all unless you used a gauge on the inside and on the outside. It was about 1.5mm more worn inside than outside, on only one wheel. Other than that it was normal. You could also have the opposite misadjustment on each side, e.g. excessive toe in on both sides, excessive toe out on both sides. Toe out probems manifest as vibrations usually, toe in as bumping in parking lots. Turn the wheel all the way and do a slow circle, gradually increasing your speed by 2 mph or so with each rotation. If it gets to 8 or 10 mph without starting to jump outward or inward (you can hear it, and you will feel your tires jumping), toe in problem is unlikely.
    Try not to get too dizzy. I guess lucky for me when troubleshooting things like this, or when playing my normal driving games, I don't.
    My eldorado's left rear still has a camber problem, one they insist can't be fixed. Spec calls for 0 degrees, it's at -0.5. Not off by much, but I don't like off at all. They claim there's no adjustment for it. Both shops and dealer claim that all there is is a $1000 job to redo the rear suspension on that side. Idiots.
    EcSTSatic's Avatar
    EcSTSatic is offline Cadillac Owners Master
    Automobile(s): 1999 STS - diamond white
    Dec 2004
    Wichita, KS
    5,212
    How much 100+ driving are you doing to even think that would cause significant wear!? I won't lecture you about driver safety but I bet someone will.
    Besides alignment probabilities mentioned, tire pressure affects wear. Also the weight of the car. That's one heavy chunk of iron, friction during contact with the pavement, especially in cornering causes wear.
    If you don't find anything amiss, you might consider cheaper tires if that's all the mileage you will get from them. Which Michelins do you have? Some are softer and wear faster than others.
    DaveSmed's Avatar
    DaveSmed is offline Cadillac Owners Connoisseur
    Automobile(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
    Aug 2003
    Bucks County, PA
    30
    2,795
    You know, I thought my crappy luck with Michelins was just me.... I always get the ones where the belt shifts, a chunk of tread departs, a sidewall bubble forms, etc... Not to mention it's been my experience that they dry rot at an above average rate. I dunno, maybe its me, maybe its not. I think i'll stick with Pirelli or Continental though.
    Elvis's Avatar
    Elvis is offline Cadillac Owners Master
    Automobile(s): '05 Expedition
    Jan 2003
    52
    7,651
    I realize it's not the same car, but it's similar--I had a 1985 Delta 88. I went through the set of factory General tires in 15,000 miles. 90% highway miles over 70 mph. Alignment was within tolerances, the car was fresh from the factory. General tires suck.
    I disagree about excessive speed. I believe it does cause premature wear, especially if the tires aren't properly inflated. You might also look into the rating. I realize they're all supposedly rated for 100+ mph, but I think that's a maximum speed rating, not a sustained speed for an extended period of time.
    Just my opinion, worth what you paid for it.
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    You run over a hundred for a long time, and often, there's obviously going to be a whole lot more heat there...check your pressures and get a new set of tires. 15,000 mile tires shouldn't be all that expensive...that's not a whole lot of miles!
    Apr 2005
    Oakland County, MI
    33
    1,320
    Rating refers to speed sustainable indefinitely. Inflation can definitely be an issue.
    FredMaxwell Guest
    Quote Originally Posted by EcSTSatic
    I don't drive over 10mph any more.. that was in another time and day for me so no need for the stories, appreciate the concern though.
    I aint sure which ones they are they have a fancy name (I will check them tomorrow for you) s
    FredMaxwell Guest
    Quote Originally Posted by Elvis
    What I always thought was this;
    Look at the maximum pressure on the sidewall,
    And give the tires three to four less psi than the maximum
    Because the pressure increases a bit when you're on the roadways
  16. #14
    FredMaxwell Guest
    Quote Originally Posted by Spyder
    Well they are 90,000 or 80,000 mile tires but I am sure there is a number of years and a "prorata BS refund so that I have to rebuy"
  17. #15
    Apr 2005
    Oakland County, MI
    33
    1,320
    No, max specs are given as cold. Add 4 psi as a general rule if tires are hot.
  18. Remove Advertisements
